10 members (Luddite, TBM, Graham, G4FUJ, IcePack, Montegue, JohnHarris, Image, RichardV6, bmgermany, John V6), 397 guests, and 43 robots.
+8Rich 92
Posts837,278
Page 3 of 5 1 2 3 4 5
Lowering the centre of gravity, are we? flag
I use it on my pre war cars . . . works a treat.
Cheers,
Mark
1934 SS MX4
1938 Series 1 DHC
1951 Plus 4
2005 Roadster
Originally Posted By GLLOQ
I solved the problem of battery...
For 48 euros the 50AH battery it is not worth buying a voltage holding charger, more battery is on sale everywhere.
That is 1 solution! My battery conditioner was I think cheaper though... although I did have problems starting once without it (embarrassingly at the front of a ferry). I might get a plug-in LiPo booster for those occasions!
Originally Posted By nippymog
I find unless I have it connected to a battery conditioner between runs I get a prolonged start , with the conditioner it starts on the button ( most times ).
Snap! C-TEK all the way for me.
I've always thought easy start was a bit evil! Fine on elderly lawnmowers, but I've heard that it can ignite on the compression stroke before the piston reaches tdc- can even ignite on the exhaust stroke. The ether is so incredibly volatile.
+8 4.8
My grandfather garage told me a story that dated before WW II he was going to visit a brother garage when he had difficulty to restart an old single-cylinder automobile older than the WW I, his colleague wanting Showed him that he knew the easy trick to start a recalcitrant automobile put a tablespoon of ether to show him start a blast engine the first explosion was right, the breech broke the screws and part Breaking at the tavers of the glass roof.
Care must be taken not to break the starter if the motor runs in the opposite direction with the modern starter.
Has anyone ever seen starting ether used to set the bead when mounting a tire? Spray a bit of ether into the tire, stand back, touch a match, and light 'er off. Bang, and the bead is set. I've watched this done, but have never had to resort to it myself. Very effective use of however! And quick!
Sounds like the Icelandic trick on 4x4 tyres smile
Online NoMood
Using ether to start an engine is akin to smashing the tops of the piston crowns with a sledge hammer.
I used to work with old Enfield diesel genny sets that actually employed an ether cartridge injection system for starting in extreeme cold. The sound when it fired after such abusive treatment (exactly as described above) grated on your mechanical sympathy ooo
My memory of easystart is a bit vague but we used to use it for starting cold diesel lorries. But I remember much talk of the engines becoming addicted to it, though sadly I can't remember the technical reason.
Nick
