1 members (DJC),
323
44
Posts837,277
Posts: 399 Likes: 15
Posts: 399 Likes: 15 |
Thanks Bunny...useful info...I did manage to change our clutch master cylinder without completely removing the pedal box but did need to undo it all and work "down the hole" to achieve this (not easy given my size) - your method may be simpler if apparently more drastic - juggling with 3 fluid reservoirs could be fun though!
Posts: 3,857 Likes: 2
Posts: 3,857 Likes: 2 |
What an excellent Post. Very useful, especially for those of us who have gearbox/clutch noises.
Posts: 1,737 Likes: 55
Posts: 1,737 Likes: 55 |
Thanks Bunny...useful info...I did manage to change our clutch master cylinder without completely removing the pedal box but did need to undo it all and work "down the hole" to achieve this (not easy given my size) - your method may be simpler if apparently more drastic - juggling with 3 fluid reservoirs could be fun though! Respect due to you JMD for changing the master cylinder in situ - it certainly beat me! Yes, I reckon that it's actually quicker to drain everything and remove the entire pedal box than mess around 'down the hole'. Plus you get to change all your hydraulic fluids at the same time (which I'm guessing most of us don't do as often as we should).
Andy
Posts: 3,732 Likes: 79
Posts: 3,732 Likes: 79 |
Plus you get to change all your hydraulic fluids at the same time (which I'm guessing most of us don't do as often as we should).  A timely reminder Bunny  The hydraulic fluids should be changed every 2 years.
Red Leader
Posts: 1,889 Likes: 16
Posts: 1,889 Likes: 16 |
yes, one of the most often neglected part of maintenance. I often use a turkey baster to empty the reservoir when I do this
