4 members (RichardV6, High Hamster, Martin W, jbk), 221 guests, and 51 robots.
+8Rich 77
Topics49,859
Posts837,513
Jonny72
Page 2 of 6 1 2 3 4 5 6
atalante83 #434586 06/03/17 12:13 PM
The Mikuni is a good carbs, but many Harley owner with S&S engine also use SU and seem's that work well after a fine tune the looking is better and the SU is more english smile
atalante83 #434595 06/03/17 12:40 PM
Advantage of Mikuni over an SU is availability and range of parts for tuning. The one I had on my Velo had so many jet and slide options it was bewildering!
But I don't think you can beat an SU for simplicity and reliability, not that many moving parts.
atalante83 #434596 06/03/17 12:54 PM
Are the M3Ws not subject to emissions control restrictions? Can a carb run cleanly enough to pass the tests?
SteveT #434598 06/03/17 12:58 PM
you got the dark point, it's why i haven't get one in my 1340 Softail with my Knucklehead S&S replica , but according to friend witch have made the move it's easy to find all part you need.
in term of look they are also unbeatable (in my eyes)
atalante83 #434599 06/03/17 01:09 PM
Here motorcycles are not subjected to emission tests at our equivalent of the MOT.
Bikes have to be Euro-4 compliant emissionswise OR have been registered for street use before Jan 1st 2017, however.
How much of the British legislation will be redone at Brexit?
Mine has been registered since 2013, so no worries. Don't think I will remove the cats anyhow.
M3W, now!!!
atalante83 #434605 06/03/17 01:25 PM
I'm not sure BREXIT will change too much legislation for the forseeable. Otherwise UK standards will become another set for imports to adhere to, and another set for those who export to adhere to (UK sales and European exports).
In fact, the cynic may even suggest that going forward we will have the freedom to chose exactly what we want, but in practice have absolutely no say in shaping what we actually [voluntarily] choose to inherit from the EU.
(This isn't a political statement, merely a pragmatic business statement)
2012 G56 Stage 2 M3W
2007 Fiat Panda 100HP
1998 Lotus Elise (Cosworth Duratec)
1988 RF88 Van Diemen
Hamwich #434607 06/03/17 01:41 PM
M3W in the UK are not subject to emission testing at the MOT. As I found out last year when the tester tried to get my car to pass the emissions test and eventually gave up, post test I found out that it was not required.
2021 M3W
2013 M3W - Sold
1971 4/4 2 Seater
1934 Sports
Rog G #434613 06/03/17 02:22 PM
Well stap me vitals, I'm amazed.
atalante83 #434617 06/03/17 03:04 PM
I
I
If the ECU goes south, this mod definitely looks like the way to go. What throat size is recommended for the carburetor option? I have boxes full of 1-1/2" SU's , would probably need to fabricate manifolds, one for each cylinder, in which case, 1-1/4" might be better. Perhaps a Weber would do better.
Inge
Inge #434625 06/03/17 03:42 PM
Remember, you still have the ignition to worry about. I know that there's a company called Thunderheart that sells standalone ignition systems for late model ECM controlled Harleys for use in like a custom bike. A Thunderheart ignition and a carb is all you'll need at that point.
Dan
