7 members (John Wilcox, Ruut Bianchi, jejemek, GrumpyPa, Montegue, Graham, G4FUJ, James B W),
258
68
Posts837,273
Posts: 3,690 Likes: 128
Posts: 3,690 Likes: 128 |
Field Marshal tractors used a blank shotgun cartridge to start. Turn to near TDC, unscrew holder & insert cartridge & screw down again. Insert lighted taper & hit cartridge with a hammer. Job done. https://www.youtube.com/watch?v=VEurohAwrmA That's amazing - I'd never heard of this before. The Coffman engine starter, also used on aero engines. Famously appears in the the 1965 film The Flight of the Phoenix where air crash survivors rebuild their wrecked pane but have only three available cartridges to get the engine running. ~iw
Posts: 15,794 Likes: 15
Posts: 15,794 Likes: 15 |
Then there was the AVPIN System, developed for RAF aircraft to overcome the limitations of the Coffman system.
AVPIN is isopropyl nitrate, it burns without additional air and has an invisible flame, although the products of combustion are pungent.
Isopropyl nitrate was also sold by the Turbonique company under the brand name "Thermolene" as a fuel for their line of turbine-powered "drag axles" and superchargers, during the 1960s.
Posts: 1,947 |
Field Marshal tractors used a blank shotgun cartridge to start. Turn to near TDC, unscrew holder & insert cartridge & screw down again. Insert lighted taper & hit cartridge with a hammer. Job done. https://www.youtube.com/watch?v=VEurohAwrmA That's amazing - I'd never heard of this before. The Coffman engine starter, also used on aero engines. Famously appears in the the 1965 film The Flight of the Phoenix where air crash survivors rebuild their wrecked pane but have only three available cartridges to get the engine running. ~iw Great film, Morgan should employ some of those guys.
Posts: 8,656 Likes: 407
Posts: 8,656 Likes: 407 |
Field Marshal tractors used a blank shotgun cartridge to start. Turn to near TDC, unscrew holder & insert cartridge & screw down again. Insert lighted taper & hit cartridge with a hammer. Job done. https://www.youtube.com/watch?v=VEurohAwrmA That's amazing - I'd never heard of this before. The Coffman engine starter, also used on aero engines. Famously appears in the the 1965 film The Flight of the Phoenix where air crash survivors rebuild their wrecked pane but have only three available cartridges to get the engine running. ~iw And again in 2004 version starring Dennis Quaid. Very dramatic when he uses the penultimate catridge just to clear fuel from flooded cylinders. I suspect even a shotgun cartridge detonating would be a softer blow than that of ether though.
Posts: 6,538 |
I loved all those! Reminded me of the starting procedure for my 1920 Triumph H No cartridges involved - but quite a lengthy procedure. A very reliable bike - and usually started first kick when everything was set correctly!
Neil
Posts: 1,947 |
1/ Pre-engage starter 2/ Turn on oil 3/ Turn on petrol 4/ Tickle float on carburettor 5/ Check car is in neutral 6/ Check oiling rate 7/ Magneto on 8/ Full retard 9/ Full air 10/Sniff of throttle
And then operate starter
See, it is easy to start a vintage Morgan.
