3 members (yobtaf, TBM, KennethM),
268
88
Topics49,871
Posts837,679
Posts: 245 Likes: 5
Posts: 245 Likes: 5 |
Run it up the road with the bonnet off. There are two triangles of rubber under the front and if missing can make this noise. It's more of a knock than a creak. Suspension bushes can do it too- don't worry you will find it - sound travels !
Posts: 541 |
Their is a plastic bit that is just over the top of the instruments, I believe it is there to keep water out of the wiring and instruments. It made all kinds of racket when hitting a bump in the road or if I hit the right RPM. I got some anti-vibration stick on pads from a hardware store to stick on the top of it. You also can find it at a good car stereo place that does installations.
1998 +8 SS Sport tuned exhaust
2013 M3W Stage ll motor kit Cats removed
Posts: 582 |
Next time you hear that sound, reach up behind the steering wheel and hold on to the ignition key housing. The housing was clicking and squeaking. Very frustrating because I heard the sound coming from farther away. My fix was a wood shim until I got around to removing a little material from the housing, good luck
Posts: 19 |
Problem with noise around dash was solved by the Service Agent. they removed the panel in the front of the dash & tightened all bolts. They also found that there is noticeable play in the LHS bush of the central steering rod, which does cause a rattle on rough surfaces. Surprising as the car has only 2,300 km. Not a safety issue.
Posts: 2,242 Likes: 72
Posts: 2,242 Likes: 72 |
It must be TADTS (They All Do That Sir), as my M3W's steering rack has some play in the LH side as well. I was told by a person that should know at the factory to put some more grease in and refit the rubber boot. I did, it made no difference. It has been the same for the last 12,000 miles without a problem or change.
