5 members (mickyb, asbojohn, Image, Luddite, Nickplus4), 391 guests, and 18 robots.
+8Rich 92
Posts837,284
Originally Posted By DaveW
This was my 2012 Duratec manifold. You can see the painted plate against the head, and the blown over 4 into 1 section.
That's a long bolt you have there, Dave! Not like you at all unless there is something that is missing.
Best Regards
Lang may yer lum reek
I'd guess that in other (Ford) applications, the OEM manifold has a thicker flange plate, so the studs are long enough for this. If the studs were cut down, the removal of the star-profiled end would mean you couldn't easily remove them if a nut became seized.
Stuart
I meant the bolt in the bottom right of the picture, not the manifold studs. It might be a bit of overkill to shorten the manifold studs.
Best Regards
All Ford original................
Long studs are in, apparently.
Dave: is there a heat shield between the exhaust and the wiper fluid tank?
My wiper fluid pump stopped working and blew the fuse several times. I assume it is related to the close distance to the exhaust pipe and the emerging heat.
Did you install the heat shield yourselve?
Hannes
once: Green M3W; 2013
now: Red 4/4 Sport; 2011
Rog Offline
Infinity Exhausts in S Gloucestershire built my stainless manifold. It’s now a nice mixture of blues and straw colours
Roger
I have Rover standard cast iron manifolds on my Plus8. A small amount of surface rust. I cleaned them with a scotchpad soaked with Pepsi. The acid in the Pepsi was tried to help cleaning and convert the rust. Worked fairly well.
It might also work on steel but probably not on stainless.
A couple of weeks ago I re-did them but tried brushing on some Kurust. They went a nice dark/black colour and I am watching to see how long for.
Hannes - yes that heat shield was my addition. A simple aluminium sheet bent to shape, and covered with reflective foil.
Did you install the heat shield yourself?
Thank you! Very good idea.
I hope you do not insist on copyright fees... smirk2
Hannes
SteveH Offline OP
Thanks TMers. I used a combination of all ideas.
1. Remove the surface rust from the manifold plate with a combo of wire wool, sandpaper
2. Clean the pipes and welds with kitchen foil and Solvol.
3. Mask up manifold pipes, studs and nuts
4. Treat manifold plate with Kurust.
5. Remove masking tape and clean brass manifold nuts.
Excellent results - just a well cared for look without going over the top.
PS. Don't know how long the Kurust matt black look will last , but definitely worth a shot.
Stingmog
