6 members (DalesPlusFour, TBM, Ruut Bianchi, Hamwich, Julian BB, Mike D), 351 guests, and 28 robots.
+8Rich 102
John V6 59
Aero 8 S5 Sound System
EV beckons....
by TBM - 14/09/26 09:45 AM
Topics49,914
Posts838,173
Georgetoad, woolfie
#44372 11/05/10 06:59 PM
5 Images
Andy Offline OP
3rd Brake Light
My solution to the Issue. DIN socket mounted next to the Cobra head and spliced into loom inboard of the existing connector
22 Comments
Andy #44377 12/05/10 06:22 AM
Green & Grown Up
Green & Grown Up
Thanks for sharing Andy, cheers
That is a simple enough solution to drilling holes through the bulkhead. I will have to check that out on the Roadster to see if there is enough space between wheel & Body to fit it in. sherlock
Very neat!
Dan
'70 Morgan +8
'65 Fiat Moretti 1500
'03 "hot rodded" Toyota Camry 5-speed
Green & Grown Up
Green & Grown Up
The gap is narrower than yours Andy, so its'back to the drawing board' idea
That is a very tidy solution, Andy.
Simon #44465 13/05/10 07:24 PM
Very neat.
Frank, I think his tyres might be lower profile than yours...
No problem. Just drill a hole through the tyre.
Dan
'70 Morgan +8
Dinodan #44472 13/05/10 11:15 PM
how about incorporating a strip LED light into the top edge of the suitcase, and then using the suggested connector?
Andy Offline OP
Graham
They are bog standard +4 tyres, would they be a different diameter to a roadster?
Andy
Andy #44490 14/05/10 12:13 PM
Interesting Andy.
Not sure when Morgan went to a lower profile tyre.
Frank, you'll have to compare tyre sizes...
Cheers,
