11 members (John V6, Arwyn Williams, JMcL, CooperMan, Pittsartist, Ricosan, Neville1, Cerberas, RichardV6, Craig Jezz, MartinB60),
320
127
Topics49,869
Posts837,659
Posts: 367 Likes: 1
3rd Brake Light
My solution to the Issue. DIN socket mounted next to the Cobra head and spliced into loom inboard of the existing connector
Posts: 3,727 |
Thanks for sharing Andy,  That is a simple enough solution to drilling holes through the bulkhead. I will have to check that out on the Roadster to see if there is enough space between wheel & Body to fit it in.
Posts: 41 |
Dan
'70 Morgan +8 '65 Fiat Moretti 1500 '03 "hot rodded" Toyota Camry 5-speed
Posts: 3,727 |
Thanks for sharing Andy,  That is a simple enough solution to drilling holes through the bulkhead. I will have to check that out on the Roadster to see if there is enough space between wheel & Body to fit it in. The gap is narrower than yours Andy, so its'back to the drawing board'
Posts: 7,933 Likes: 132
Posts: 7,933 Likes: 132 |
That is a very tidy solution, Andy.
Posts: 28,904 Likes: 352
Posts: 28,904 Likes: 352 |
Very neat.
Frank, I think his tyres might be lower profile than yours...
Posts: 41 |
No problem. Just drill a hole through the tyre.
Dan
Posts: 851 |
No problem. Just drill a hole through the tyre. how about incorporating a strip LED light into the top edge of the suitcase, and then using the suggested connector?
Posts: 367 Likes: 1
Posts: 367 Likes: 1 |
Graham They are bog standard +4 tyres, would they be a different diameter to a roadster?
Andy
Interesting Andy. Not sure when Morgan went to a lower profile tyre. Frank, you'll have to compare tyre sizes...
Cheers,
