0 members (),
333
43
Posts837,990
Posts: 69 |
I appear to have a small coolant leak which appears on the near side chassis member underneath the coolant bottle and I have looked around his area and could not find any trace of the leak Tried to post a picture with no success
Regards John
Posts: 3,550 Likes: 5
Posts: 3,550 Likes: 5 |
It's the various hoses and fittings at the back of the engine, hose clips probably need doing up.
Mr Neoprene did a post with pictures on this very issue with his, iirc he replaced some of the hoses.
Posts: 22,370 Likes: 354
Posts: 22,370 Likes: 354 |
John, check the hose clips on the coolant tank. They sometimes develop a slight leak which runs down behind the washer bottle onto the chassis rail.
Posts: 54 Likes: 2
Posts: 54 Likes: 2 |
I had a similar issue in this area. After much liking I found the washer bottle had cracked at the back out of site. A small amount of silicon sealant on thecrack stopped it
Supersport
Posts: 853 |
Have you tried Evans Waterless coolant because if no water there should be no leak, unless there are fish involved?
Ken A. Plus 4 2009 Centenary Metallic Red Plus 8 1994 Dark Green (prev) Honda CB100 The Big One
Posts: 37,476 Likes: 988
Posts: 37,476 Likes: 988 |
Posts: 5,182 Likes: 2
Posts: 5,182 Likes: 2 |
I hope no fish were injured in this process.
Posts: 11,616 Likes: 43
Posts: 11,616 Likes: 43 |
Did someone mention fish?
Posts: 69 |
Well at last fixed the leak It was on the heater expansion T Piece After replacing I could not find any crack or pinhole on the old one however it could be when it gets hot the crack appears !!!
