5 members (+8Rich, aerotaff, Bishmog, John V6, simon8201), 203 guests, and 32 robots.
+8Rich 90
Luddite 50
Posts837,961
JohnS Offline OP
I appear to have a small coolant leak which appears on the near side chassis member underneath the coolant bottle and I have looked around his area and could not find any trace of the leak
Tried to post a picture with no success
Regards
It's the various hoses and fittings at the back of the engine, hose clips probably need doing up.
Mr Neoprene did a post with pictures on this very issue with his, iirc he replaced some of the hoses.
Mark - No Longer driving
John, check the hose clips on the coolant tank. They sometimes develop a slight leak which runs down behind the washer bottle onto the chassis rail.
I had a similar issue in this area. After much liking I found the washer bottle had cracked at the back out of site. A small amount of silicon sealant on thecrack stopped it
Supersport
Have you tried Evans Waterless coolant because if no water there should be no leak, unless there are fish involved?
Ken A.
Plus 4 2009 Centenary Metallic Red
Plus 8 1994 Dark Green (prev)
Honda CB100 The Big One
Very dry Ken...
Ray Offline
I hope no fish were injured in this process.
Did someone mention fish?
JohnS Offline OP
Well at last fixed the leak
It was on the heater expansion T Piece
After replacing I could not find any crack or pinhole on the old one however it could be when it gets hot the crack appears !!!
