Topics49,888
Posts837,889
Posts: 228 |
Presumably you wouldn't need a long pin. Two short ones which dropped through the the top of the bracket would do the same job.... Yes can't see why not - presumably it's just a bit more fiddler Could be, but may be easier to source...... Just a thought.
Andy
2011, 4/4, 2.0, 75th Anniversary 2016, VW Polo GTI 2012, BMW 520d Touring
Posts: 11,616 Likes: 43
Posts: 11,616 Likes: 43 |
Presumably you wouldn't need a long pin. Two short ones which dropped through the the top of the bracket would do the same job.... Yes can't see why not - presumably it's just a bit more fiddler Could be, but may be easier to source...... Just a thought. Yes agree Although getting two brass or stainless rods at a certain diameter cut to length then having both ends threaded using a die 4 stainless acorn nuts - one glued at one end of each won't be a huge job
Posts: 6,960 Likes: 117
Posts: 6,960 Likes: 117 |
What a great idea for QD version Maybe I'm thick Graham - what does QD mean? Quick Detach as opposed to QR?
GaB
Unregistered
GaB
Unregistered
Top tip Stewart. I have started to get used to them and they do look rather good, and very retro/trad. The perspex on mine is cracked, so I have the option of a new pair of deflectors or the whole shabang. Are they still produced by Life's, or are you setting yourself up in production?
Top tip Stewart. I have started to get used to them and they do look rather good, and very retro/trad. The perspex on mine is cracked, so I have the option of a new pair of deflectors or the whole shabang. Are they still produced by Life's, or are you setting yourself up in production? I got mine from Heart of England
Posts: 28,909 Likes: 354
Posts: 28,909 Likes: 354 |
Sorry Stewart and thanks Bob. At Prescott all weekend, so only now starting to pick up on the couple of hundred posts since Friday night
