2 members (Cat302, MOGDave),
285
37
Topics49,844
Posts837,360
Posts: 429 |
What size for the mikalor clamps? They are W4 63-68mm. (W4 being the width). The bolts are stainless so are likely to strip if tightened too enthusiastically. The factory use Holts exhaust sealant on those joints which guarantees they don't turn but makes disassembly more difficult.
Posts: 8,664 Likes: 408
Posts: 8,664 Likes: 408 |
What size for the mikalor clamps? They are W4 63-68mm. (W4 being the width). The bolts are stainless so are likely to strip if tightened too enthusiastically. The factory use Holts exhaust sealant on those joints which guarantees they don't turn but makes disassembly more difficult. But not on my 2016 car  . They just slid off after undoing clamps and supports, which did surprise me as was expecting a fight.
Posts: 402 Likes: 3
Posts: 402 Likes: 3 |
I gave my 2012 (but new chassis in 2014) car a good jollop of WD40 on the joint the night before and the pipe joint came apart easily.
Tim
Posts: 1,671 |
What size for the mikalor clamps? eBay item 221623600550 63mm - 68mm as previously mentioned
Posts: 1,737 Likes: 55
Posts: 1,737 Likes: 55 |
Tim +1 On using penetrating oil on the joint for a day or two before removal. I was dreading taking mine apart but the joints just slipped apart no problem once the clamps were loosened.
Andy
