Posts837,276
Posts: 2,539 |
Posts: 2,822 Likes: 155
Posts: 2,822 Likes: 155 |
Trouble is that you must remove all trace of coatings for it to work, if not then where the coating is intact you get a possibly false negative and where there's remnants of coatings or damaged coatings you get possibly false positives. Also, if you use mechanical methods to remove the coatings such as wire brushes or grit blasting you can peen over any fine cracks which gives false negative results while producing a rough surface that will hold the dye and obscuring any crack indications that are there. I'd stick to close visual inspection with good lighting, a mirror and a magnifier.
Posts: 1,947 |
Had word from the dealer MMC are fitting the new compensator in my new chassis. No indication of completion date.
Tim
Posts: 1,947 |
Word from the dealer Morgan say my car is almost ready & they should road test this week. That's 8 weeks its been away. So hopefully another week I'll have it back.
Tim
Posts: 5,654 Likes: 4
Posts: 5,654 Likes: 4 |
Tim Great news Tim
Martin (Deano)
Posts: 6,538 |
That's good news Tim .
And you will have all,the summer to enjoy your car!
Well done!
Neil
Posts: 37,403 Likes: 977
Posts: 37,403 Likes: 977 |
Great news and Summers on the way.
Posts: 7,342 Likes: 49
Posts: 7,342 Likes: 49 |
As an employee at Isis Imports (Morgan Cars USA) in San Francisco, I am very sympathetic to this issue and am doing all I can to find a viable solution. And we are your closest Morgan dealer, however I believe the Morgan was purchased elsewhere? (Apologies if I am mistaken about this) Not that this would discourage us from wanting to help you...3 Wheelers are meant to be enjoyed - to have it sit unused makes me unhappy and I am so sorry this has been an issue for so many.
Sincerely,
Tcherek Nice response, direct and heartfelt
Posts: 1,947 |
Still no further word from Morgan despite saying last week its nearly fixed. Nine weeks now its been away. What are they doing?
Tim
Posts: 541 |
Sorry to hear about the Morgan service. But like I've said before, typical Morgan no service. 🙁
1998 +8 SS Sport tuned exhaust
2013 M3W Stage ll motor kit Cats removed
