Topics49,851
Posts837,442
Posts: 1,103 Likes: 2
Posts: 1,103 Likes: 2 |
I am still very confused.
After some issues with no starts and suspect Fuel Pump Relay (see earlier thread) I have now got car starting but the voltage at the fuel pump and the inertia switch is still 7.35v. How can this be? Does anyone have a wiring diagram as the ones we have all shared show the cables disappearing into the 'Engine Loom' and I cannot see the wiring from to the inertia switch and pump.
OMEX suggests that there should be 12v??
This is driving me crazy...
Keith
Car 54 - 'Le Mans 62' 4/4 Supersport OxMog Member (and associated with CranMog and SwanMog)
Posts: 3,550 Likes: 5
Posts: 3,550 Likes: 5 |
What resistance measurements are you getting across the cables from one connection to another?
Ie if you have a corroding wire it'll have a high resistance and drop volts.
Posts: 932 Likes: 11
Posts: 932 Likes: 11 |
Hello Keith I had the same voltage problem and contact spray ( Multi Super 5) on the connections took away the problem,.......afther some recherche. Check also negative connection.
Stefan
Posts: 1,075 Likes: 1
Posts: 1,075 Likes: 1 |
Could be an earthing problem..Check the engine block earth strap.
Posts: 1,703 Likes: 35
Posts: 1,703 Likes: 35 |
Hi Keith. Did you record 7.35v with the motor connected or disconnected? I wonder whether you have a slow pump with high resistance owing to a dirty/tarnished commutator on the DC motor. Can you take the pump out and run it on the bench? If you do manage to run it you stand a chance of self-cleaning the commutator. Just a thought.
Roger 2011 Plus 4
With pump connected. I ended up pulling the fuse box holder off to check which fuse was what and then found fuse were not as indicated on diagram (why am I not surprised!). After much faffing around I tried it again and all good! I suspect the wire loom as it drops down to the engine bay near the battery as it was very tight against the footwell. I have relieved some strain and placed neoprene under it.
Keith
