1 members (cerealsurfer),
334
84
Topics49,880
Posts837,761
Posts: 180 |
My S1 now has its new exhaust, twin pipe side exit. So it is larger bore than the original & a shorter length run. The issue is when warm, & coming onto idle, say when slowing down for lights, the idle speed hunts a little. Has anyone else found this or has any suggestions please?
Posts: 2,432 Likes: 17
Posts: 2,432 Likes: 17 |
Bet it sounds awesome! Sorry can't help but are you sure it's the exhaust and not just a coincidence ? Like the MAF Sensor?
1969 4/4 1995 plus 8 1996 Plus 4 4seater 2002 Aero S1 2013 M3W 2014 Plus 8
Posts: 180 |
I have to say it sound epic, like a C63 AMG Mercedes, but subdued on the motorway.
It could be the lambda or the MAF I guess, just wondered if anyone else had a similar issue when carrying out a significant exhaust mod. I guess it'll become a process of elimination.
Does anyone know the manufacturer & correct part numbers for these 2 items (2001 4.4 S1). I'll give the ECU some miles to see if it relearns, but I suspect I'll have to start replacement these instruments one at a time. I wondered if it was something that might benefit from resetting the ECU, if I can find how to do that on a BMW forum.
Posts: 1,767 Likes: 21
Posts: 1,767 Likes: 21 |
come on Ian, we need to see some pictures of the new set up - preferably with a sound clip too  James
Aero8 , Series 1 - Boston Green RR Evoque P300E Autobiography Smart Brabus Convertible Monkey Z125
Posts: 180 |
I have tried to load pics without success. I tried following the idiots's guide but failed - not sure if a failure means I'm an idiot or not....
Posts: 844 |
No, can't see the pics.....
Series 1 Aero 8
Posts: 5,659 Likes: 5
Posts: 5,659 Likes: 5 |
Looks a very neat job. Just something to keep an eye on. On my plus 8 the pipe outlets move rearwards approximately 15mm when hot. Hence when cold, the outlets are not in the centre of the aperture.
Martin (Deano)
Posts: 378 |
Hi Ian, I never had any issues when I "converted" to side exhausts, but before I certainly did and it was certainly the MAF sensor. In the end it did keep cutting out. It may be that they might be a bit dirty - might be a cheaper fix! By the way, if you pass slowly past "new style" parked minis I have noticed on a number of occasions the exhaust rumble sets off their alarms!;)
15 Weissman GT5 11 Aero8 SS 21 Q7 23 RR 24 Def'r 130 1960 XK150 DHC 1970 E-type 2024 Huracan Tech
Posts: 180 |
Hi Taffy
Thanks for the thoughts on the MAF, have you got a part number or is it standard BMW 645?
If it's a BMW part, I might need to drive slowly past their affiliate Mini forecourt on the way out :-)
Deano
15mm linear expansion sounds incredible to me on an exhaust system!!
