Morgan Aero 8
7 members (Strathaven, DCH, teknome, Ben S, gomog, TeddyAds, Plus Four Guy), 319 guests, and 85 robots.
+8Rich 66
Oil level reading
by moggin - 05/09/26 01:58 AM
Topics49,877
Posts837,735
My S1 now has its new exhaust, twin pipe side exit. So it is larger bore than the original & a shorter length run. The issue is when warm, & coming onto idle, say when slowing down for lights, the idle speed hunts a little. Has anyone else found this or has any suggestions please?
Bet it sounds awesome! Sorry can't help but are you sure it's the exhaust and not just a coincidence ? Like the MAF Sensor?
1969 4/4
1995 plus 8
1996 Plus 4 4seater
2002 Aero S1
2013 M3W
2014 Plus 8
I have to say it sound epic, like a C63 AMG Mercedes, but subdued on the motorway.
It could be the lambda or the MAF I guess, just wondered if anyone else had a similar issue when carrying out a significant exhaust mod. I guess it'll become a process of elimination.
Does anyone know the manufacturer & correct part numbers for these 2 items (2001 4.4 S1). I'll give the ECU some miles to see if it relearns, but I suspect I'll have to start replacement these instruments one at a time. I wondered if it was something that might benefit from resetting the ECU, if I can find how to do that on a BMW forum.
come on Ian, we need to see some pictures of the new set up - preferably with a sound clip too thumbs
James
RR Evoque P300E Autobiography
Smart Brabus Convertible
Monkey Z125
I have tried to load pics without success. I tried following the idiots's guide but failed - not sure if a failure means I'm an idiot or not....
http://s1152.photobucket.com/user/Volvos60s60/media/Mog%203_zpsbmjka2ic.jpg.html?filters[user]=146445264&filters[recent]=1&filters[publicOnly]=1&sort=1&o=1
Not sure if these can be viewed
The keen eyed will note the missing indicator - now firmly reaffixed !!
No, can't see the pics.....
Series 1 Aero 8
Looks a very neat job. Just something to keep an eye on. On my plus 8 the pipe outlets move rearwards approximately 15mm when hot. Hence when cold, the outlets are not in the centre of the aperture.
Martin (Deano)
Hi Ian,
I never had any issues when I "converted" to side exhausts, but before I certainly did and it was certainly the MAF sensor. In the end it did keep cutting out. It may be that they might be a bit dirty - might be a cheaper fix!
By the way, if you pass slowly past "new style" parked minis I have noticed on a number of occasions the exhaust rumble sets off their alarms!;)
15 Weissman GT5
11 Aero8 SS
21 Q7
23 RR
24 Def'r 130
1960 XK150 DHC
1970 E-type
2024 Huracan Tech
Hi Taffy
Thanks for the thoughts on the MAF, have you got a part number or is it standard BMW 645?
If it's a BMW part, I might need to drive slowly past their affiliate Mini forecourt on the way out :-)
Deano
15mm linear expansion sounds incredible to me on an exhaust system!!
