9 members (TBM, Sir Percival, Mark+4, Ian Wegg, Luddite, Burgundymog, Neville1, RichardV6, TheRabbit),
264
74
Topics49,867
Posts837,624
Posts: 91 |
Kirk, that a great mod! Thank you! 2 questions: 1. Where did you get the new white light? 2. Does it come on only when reversing?
2017 Morgan 3 Wheeler -BRG Shark 2008 Lotus Elise California Edition -Red 2009 Land Rover LR2 -Black
Posts: 1,544 Likes: 1
Posts: 1,544 Likes: 1 |
Just change 1 pin the earth is common to both!
Posts: 439 Likes: 3
Posts: 439 Likes: 3 |
Nice work! I suspect I also would have more use for a reversing light than a rear fog light... Do you happen to have the Morgan AUS part number handy?
Posts: 91 |
Do you happen to have the Morgan AUS part number handy? I think it's there on the box in the picture. Dasteri DSL0400RVL Now the question is, where to buy it in the US?
Posts: 2,539 |
I asked a Morgan dealer , who happened to have one on the shelf. I wired it up to the existing Fog Lamp switch, so I can control it independently of the gear shift position.
Posts: 2,539 |
Nice work! I suspect I also would have more use for a reversing light than a rear fog light... Do you happen to have the Morgan AUS part number handy? Morgan part number is U340027 LED reversing lamp
Posts: 2,539 |
It MAY be this light, I am not sure, again I got mine from the dealer. http://www.carbuildersolutions.com/uk/led-55mm-reverse-light
Posts: 2,539 |
Posts: 91 |
It looks like you put a furniture dolly under the rear tire. Do you jack it up and then put the dolly under for easy moving? Do you do anything with the front tires?
Posts: 2,539 |
Yes its a low budget way to slide things around or lift the car slightly.
