4 members (IcePack, David_E, PaulJ, DaveW), 339 guests, and 86 robots.
Topics49,848
Posts837,408
DazMog, The Impaler, tlchzj79
Page 89 of 108 1 2 87 88 89 90 91 107 108
Kirk, that a great mod! Thank you! 2 questions:
1. Where did you get the new white light?
2. Does it come on only when reversing?
2017 Morgan 3 Wheeler -BRG Shark
2008 Lotus Elise California Edition -Red
2009 Land Rover LR2 -Black
Just change 1 pin the earth is common to both!
Nice work! I suspect I also would have more use for a reversing light than a rear fog light... Do you happen to have the Morgan AUS part number handy?
I think it's there on the box in the picture. Dasteri DSL0400RVL
Now the question is, where to buy it in the US?
Draggin Offline OP
I asked a Morgan dealer , who happened to have one on the shelf.
I wired it up to the existing Fog Lamp switch, so I can control it independently of the gear shift position.
kirkusblog.com
1952 Ford 8N
Draggin Offline OP
Morgan part number is U340027 LED reversing lamp
kirkusblog.com
1952 Ford 8N
Draggin Offline OP
It MAY be this light, I am not sure, again I got mine from the dealer.
http://www.carbuildersolutions.com/uk/led-55mm-reverse-light
kirkusblog.com
1952 Ford 8N
Draggin Offline OP
I also did a little photo post on my cockpit sealing.
https://kirkusblog.com/2017/05/08/adventures-in-morganeering-cockpit-sealing/
kirkusblog.com
1952 Ford 8N
It looks like you put a furniture dolly under the rear tire. Do you jack it up and then put the dolly under for easy moving? Do you do anything with the front tires?
Draggin Offline OP
Yes its a low budget way to slide things around or lift the car slightly.
kirkusblog.com
1952 Ford 8N
