2 members (sezznowt, cerealsurfer), 87 guests, and 52 robots.
+8Rich 75
Luddite 50
Hacked email account
by +8Rich - 08/09/26 01:47 PM
Guess the car
by Soleng - 07/09/26 06:44 PM
by +8Rich - 07/09/26 06:43 AM
Some real stars on here
by +8Rich - 07/09/26 02:42 AM
Topics49,889
Posts837,890
Same as Ray. Stainless standard issue nuts. No idea of the taper.
Am I worried?
No.
The studs are high tensile steel and bear the brunt of the forces involved. The nuts are there to hold the wheel in place and provided they are torqued correctly then little to worry about.
If I decide to replace a bolt/nut/screw then I consider stainless unless it is for an obvious safety critical component. It is then like for like.
I buy from well established and reputable suppliers.
ebay? Treated with great care! Cheap Oriental electric stuff! NEVER.
I concur with howard re the grades of steel. As a metallurgist in college we used to get books from Climax Molybdenum Company as textbooks. They were great books and free giveaways! Covering stainless steels with details of grades composition, heat treatment, uses etc.
For an individual to order a couple of stainless, heat treatable and hence stronger, ss bolts/nuts would be expensive. A2 and A4 are the general purpose grades, A4 prefered for marine use as better corrosion protection. YES..ss does corrode! Welding of ss is also an area for careful choice, perhaps more so than carbon steels.
In all my Morgan rebuilds, I've used stainless steel fasteners unless its a highly stressed part when I will use new factory or Morgan specialist parts. Highly stressed is front and rear suspension, brakes and transmission. I don't buy fasteners from overseas either as I have access to large quantities of ex MoD fasteners. (cost negligible but getting storage grease off is messy!)
An example: I once dismantled a Plus 4 which had been in a high speed impact. The front rear spring bolts were bent into an S shape. I've no doubt that a stainless bolt would have simply sheared off.
Getting things into perspective, let us not forget that wire wheeled cars have only one nut and that's of chrome plated brass!
Arwyn
