8 members (Image, RichardV6, Graham, G4FUJ, sewin, Dinko, B3MOG, James B W, Strathaven),
250
Topics49,908
Posts838,114
Posts: 165 |
The time is never right. Anyone else with this issue?
Posts: 99 |
...i've never looked at a clock when out in my M3W or in one of my old school hot rods. When the sun starts to go down it's time to head home! High Noon Speed Shop Blog: https://ontheroadtonowhereville.wordpress.com/
Posts: 136 |
The time is never right. Anyone else with this issue? there's a clock??
1959 4/4 - sold 1957 +4 - sold 2017 M3W - sold
Posts: 541 |
...i've never looked at a clock when out in my M3W or in one of my old school hot rods. When the sun starts to go down it's time to head home! +1
1998 +8 SS Sport tuned exhaust
2013 M3W Stage ll motor kit Cats removed
Posts: 303 |
I use it all the time and the time been right from the day I picked it up , as I use my 3 wheeler most days , need to no the time , it's not just for sunny sundays
Posts: 1,948 |
The time is never right. Anyone else with this issue? You must be really living up to your 'fast' epithet, Ken. As Einstein predicted, when you approach relativistic speeds, you will notice a slowing of time...
Stuart "There's no skill substitute like cubic inches."
Posts: 37,486 Likes: 992
Posts: 37,486 Likes: 992 |
A clock in a Morgan - whatever next  .
Posts: 1,490 |
The Original Ken 11,000 miles.
2014 BMW R9T 2005 Saabaru 2005 Saabaru
Posts: 5,017 Likes: 3
Posts: 5,017 Likes: 3 |
When using the red main switch to disconnect electricity the clock always sets for 12:00. Get yourself an independent clock!
Posts: 402 Likes: 3
Posts: 402 Likes: 3 |
I purchased a little battery clock at Blenheim all Morgans Day last year (afraid I can't remember from whom). Just got round to fitting it. I didn't want it to interfere with the left hand panel but recently realised it could go straight in front of the steering wheel, where it would be easy to read.  The clock has a back turning which it plugs into. This could be bolted through the dash panel using a modified Allen bolt as seen in the picture below - basically the head much reduced to clear the clock mechanism and its outer case.  This was bolted to the dash, with contact spray adhesive on the back to hold it against loosening on the engine turned panel.  Final picture shows it in place. No more fiddling with the silly digital clock. The good thing is that if the clock fails, the whole assembly can be easily removed and revert to the previous condition.  Tim
