2 members (ChrisM, Tresco), 272 guests, and 34 robots.
+8Rich 97
Luddite 54
Topics49,904
Posts838,088
The time is never right. Anyone else with this issue?
...i've never looked at a clock when out in my M3W or in one of my old school hot rods. When the sun starts to go down it's time to head home!
High Noon Speed Shop
Blog: https://ontheroadtonowhereville.wordpress.com/
JFP Offline
there's a clock??
1959 4/4 - sold
1957 +4 - sold
2017 M3W - sold
+1
1998 +8
SS Sport tuned exhaust
2013 M3W
Stage ll motor kit
Cats removed
I use it all the time and the time been right from the day I picked it up , as I use my 3 wheeler most days , need to no the time , it's not just for sunny sundays
You must be really living up to your 'fast' epithet, Ken.
As Einstein predicted, when you approach relativistic speeds, you will notice a slowing of time...
Stuart
A clock in a Morgan - whatever next grin2.
Mines spot on.
The Original Ken
11,000 miles.
2014 BMW R9T
2005 Saabaru
2005 Saabaru
When using the red main switch to disconnect electricity the clock always sets for 12:00.
Get yourself an independent clock!
Hannes
once: Green M3W; 2013
now: Red 4/4 Sport; 2011
I purchased a little battery clock at Blenheim all Morgans Day last year (afraid I can't remember from whom). Just got round to fitting it. I didn't want it to interfere with the left hand panel but recently realised it could go straight in front of the steering wheel, where it would be easy to read.
The clock has a back turning which it plugs into. This could be bolted through the dash panel using a modified Allen bolt as seen in the picture below - basically the head much reduced to clear the clock mechanism and its outer case.
This was bolted to the dash, with contact spray adhesive on the back to hold it against loosening on the engine turned panel.
Final picture shows it in place. No more fiddling with the silly digital clock. The good thing is that if the clock fails, the whole assembly can be easily removed and revert to the previous condition.
Tim
