Topics49,878
Posts837,753
Posts: 12,263 Likes: 320
Posts: 12,263 Likes: 320 |
Ken,
I consider Smart Meters are, at the moment, pointless.
Why?
Certainly they are of benefit to the supply company, as they remove the need for a meter reader...but it is unclear if, should you change supplier, if the new supplier can access the smart meter. So until Smart Meters are "universal" they only help discourage change.
All the other reasons touted by the supply company are spurious. I really don't need to know, moment by moment, how much power I'm using. The meters don't in my view, provide data that facilitates sensible management of consumption. We use the power we need, we have LED lights almost everywhere and we mostly turn off devices we are not using.
I will decline a smart meter if and when offered: Sorry to say Peter you are 100% wrong in this regard. Have a look at the 'Faster switching' initiative and how the DCC uses the smart technology to make it easier, not harder to change supplier. If you're not interested in optimising your energy usage then a Smart meter is probably not for you, but you'll end up paying more for your power. It's true that Smart meters reduce the measuring and billing costs for suppliers, and they will be able to reflect that in their tariffs. Customers who choose not to take advantage of the technology will naturally not be able to benefit from the reduced rate tariffs. There are lots of companies out there developing smart apps which use a combination of appliance databases and smart data to give a live view of your energy consumption at 15-second granularity. Current pilots are using standard appliance profiles, the next generation will know the specific consumption profiles of particular models, so you'll be able to see how much an AEG 123 will compare to a Zanussi XYZ for your particular usage pattern. KenA: for your particular requirement, I would think a monitoring plug as Alistair and others have already suggested would be the way to go. If you want to get really technical about measuring the true consumption of appliance, you'll need to read up on Power Factors. Devices like Fridges and Freezers quite often take power out of phase with voltage, meaning they appear to use more power than they actually do. Simple monitors are unable to measure this so they don't give a totally accurate view.
On a related topic, if anyone's interested in a high-efficiency Solar PV installation with integral battery storage, you might want to check out the Smartflower system. http://youtu.be/vZuQOUA9rLk
Posts: 5,945 Likes: 28
Posts: 5,945 Likes: 28 |
We have solar PV and have just had a smart meter installed. Does anyone else here have the same as I need to share an issue. The intended benefit of the smart meter (for me as a user) is to be able to monitor consumption by individual appliances. However all the time the solar PV is generating, the indicated "consumption now" is reduced by the solar PV generated, often showing a negative consumption. As the solar PV is constantly varying, it is impossible to monitor the consumption of any appliances. I have spoken with E.ON, our supplier but they are useless and failed to resolve. I have also been in communication with SmartEnergyGB, but they also could not help. Ideas? I was going to say simple basic physics but it isnt even that. Every appliance has a rating in watts and thats what they use.If you cant see the label then lookm it up on the net. The only issue really are those that are intermittent like fridge, freezer, boiler but then without the solar, the smart meter would still give intermittent demand numbers as these units switched in and out. I'm puzzled about what you are trying to achieve or expect from the smart meter. What do you want to know / expect it to say?
Posts: 15,794 Likes: 15
Posts: 15,794 Likes: 15 |
Ken,
Why?
I will decline a smart meter if and when offered: Sorry to say Peter you are 100% wrong in this regard. Have a look at the 'Faster switching' initiative and how the DCC uses the smart technology to make it easier, not harder to change supplier. If you're not interested in optimising your energy usage then a Smart meter is probably not for you, but you'll end up paying more for your power. It's true that Smart meters reduce the measuring and billing costs for suppliers, and they will be able to reflect that in their tariffs. Customers who choose not to take advantage of the technology will naturally not be able to benefit from the reduced rate tariffs. There are lots of companies out there developing smart apps which use a combination of appliance databases and smart data to give a live view of your energy consumption at 15-second granularity. Current pilots are using standard appliance profiles, the next generation will know the specific consumption profiles of particular models, so you'll be able to see how much an AEG 123 will compare to a Zanussi XYZ for your particular usage pattern. KenA: for your particular requirement, I would think a monitoring plug as Alistair and others have already suggested would be the way to go. If you want to get really technical about measuring the true consumption of appliance, you'll need to read up on Power Factors. Devices like Fridges and Freezers quite often take power out of phase with voltage, meaning they appear to use more power than they actually do. Simple monitors are unable to measure this so they don't give a totally accurate view. Not wrong, out of date!! Last time I asked the provider they said that if I changed providers I'd have to change meters.... Se have changed provider since then, so perhaps I should ask again. Thanks for the "heads up"... Not that interested in optimising power use, but do want the best deal.....so I guess a smart meter is inevitable.
It's true that Smart meters reduce the measuring and billing costs for suppliers, and they will be able to reflect that in their tariffs. I like your sense of humour!
Posts: 6,958 Likes: 117
Posts: 6,958 Likes: 117 |
Thanks I have PV panels and my provider is pushing for a smart meter. Hold off as long as possible. Just now you are getting 50% of your production estimated as fed in for the extra small tarriff. If you get a smart meter that will go down drastically.
The more I think about this thread, the more it puzzles me. Monitoring your energy consumption is easy - just take a quarterly meter reading and put it on a spreadsheet. Checking for big consumers again is easy. Look at the labels on them.
But even if your energy consumption data is as granular as a bag of sugar, whats the reality of the action you can take? Are you going to turn off the heater and sit in the cold ? Are you going to turn off the freezer, TV, fridge? Or go to work in unironed shirts. And god forbid you try to take away SWMBOs hair dryer or curlers.
So in reality there is very little you can do once you have done what is obvious even without grainy data - things like switching off lights, not leaving the immersion heater on 24/7 etc.
And then of course there is the money gained by all this attention. Unless you have electric home heating your leccy bill will be far smaller than the home heating bill. Mine for 4300 kwh is only £617pa . So what do you do to make a worthwhile sum out of reducing that figure? And will you do it anyway?
Seems to me that there are far more fruitful areas for some focussed penny pinching. My annual insurance bill approaches £3k!!!! And that isnt remotely granular - it comes in sodding great chunks.
Posts: 853 |
Firstly, many thanks for the info and comments so far. This is important to us as we are all electric and our heating is Air Source Heat Pump and it is this that i would really like to monitor but with the solar element it is not possible. I have emailed Elgato systems to see if they can help as the unit runs at up to 20Amps. Bob, you are not correct about the export figures. Before i queried the issue i made sure that the export quantity was not affecting the meter reading. That is why i can't get my head around this. As i said the "usage now" on the in home display regularly shows a negative ie exporting amount but even if i turn everything off the meter count does not go backwards. So the smart meter shows the export but does not record it. In the end as we spend about £1500 a year on electricity i think it is worth a little effort to keep it to a min. I wont though be persuaded to spend a fortune on stuff to monitor it as the smart (or dumb) meter should have helped me much more than it is. As has been said the only winners here are the elec co's who now don't have to visit to get their reading. Unless that is, the mobile signal fails........now that's another thread as we only get 1 bar if we are lucky.....
Ken A. Plus 4 2009 Centenary Metallic Red Plus 8 1994 Dark Green (prev) Honda CB100 The Big One
Posts: 11,533 Likes: 318
Posts: 11,533 Likes: 318 |
Sadly i think the Elgato is only domestic.
Posts: 853 |
Quite surprised that when you have panels or other generating devices fitted as a matter of function that there aren't multiple reading points to give an accounted balance.
There are cases where people have been supplying their neighbours, a guy I work with had had this problem when he lived in Andover.
It probably wouldn't take much to fit another meter on the consumer side but obviously that would be at the customers expense no doubt as it's of no benefit to the supplier. Mark We do have a separate meter that counts the amount of elec we generate, however the amount that we export to the grid when we are not using it ourselves, is "deemed" to be 50% of what we generate. In reality i think we probably export more than 50% but the cash numbers are minor, about £100-£120 per year so not a worry. Regarding "supplying a neighbour" i question this, what we do is, when not consuming what we generate, we feed the grid, and of course this might be, in part, consumed by a neighbour but they will be charged for that by their supplier.
