1 members (Saxonian),
359
Topics49,904
Posts838,088
Posts: 722 Likes: 24
Posts: 722 Likes: 24 |
When riding with my wife's M3W I found that steering was much more heavy as with mine. Jacked up both vehicles and there was an enormous difference. Found out that three of the four king pins where almost frozen in their housing. What the reason was for this I really don't know. When I ordered new ones my dealer told me that MMC only delivers the king pins including new arms ?! I only installed the new king pins so anyone interested in new arms ? This new king pins improved the steering in a huge amount.
Posts: 902 |
Laurens, do you have a photo of the parts?
Posts: 303 |
The older they get , more problems are coming up ? good to see you have got it fixed 😀
Laurens, do you have a photo of the parts?  This picture is without the rubber on it
Posts: 2,822 Likes: 155
Posts: 2,822 Likes: 155 |
They are a very standard ball joint. I'm offshore at the moment so can't get the part number just now. Should be just a few pounds/dollars/francs each.
Posts: 439 Likes: 3
Posts: 439 Likes: 3 |
How many miles?
Have to say, I've had many bad ball joints over the years, and all that I have seen get loose and sloppy as they wear. Don't recall any that ever mad it harder to steer - odd.
Posts: 902 |
How many miles?
Have to say, I've had many bad ball joints over the years, and all that I have seen get loose and sloppy as they wear. Don't recall any that ever mad it harder to steer - odd. Trust me, back in the 80`s i had a mk3 ford cortina. Ball joints were replaced very often. Especially when the steering got very stiff.
Posts: 368 Likes: 1
Posts: 368 Likes: 1 |
The new "arms" as you refer to them will cure bump steer in older cars as the arms are about three inches higher then the originals. The arms position the track rods at the same height as the comfort kit.
Posts: 786 Likes: 18
Posts: 786 Likes: 18 |
See also the steering rack is not oxidized, remove the rubber bellows to check.
Posts: 1,796 Likes: 5
Posts: 1,796 Likes: 5 |
I do believe they are Metro ball joints.
