8 members (thelastgizmo, Luddite, JohnHarris, Mike D, Craig Jezz, DJC, +8Rich, Montegue),
275
42
Posts837,993
Posts: 439 Likes: 3
Posts: 439 Likes: 3 |
Thanks! Are they just sealed on the front, or the back also? Not sure that would be needed, but sitting in the rain, could see the possible need.
Posts: 402 Likes: 3
Posts: 402 Likes: 3 |
KH fitted the Fairborne screen to my car. Can't say they made a particularly tidy job of the sealant and so I made and fitted some stainless steel trim around the bottom - this also improves sealing. More of it is described fairly early on in my Hertsmog thread)..  I think Melvyn Rutter fit a replacement stainless steel L angled front pillar in the middle, which is screwed into the scuttle. This makes the assembly more rigid. My limited experience of driving with the standard screens certainly made me get the Fairbourn fitted. It does keep a lot of the wind and rain off. Tim
Posts: 1,544 Likes: 1
Posts: 1,544 Likes: 1 |
With the higher screen is it necessary to have wipers?
Posts: 103 |
Only if you can't see over the top😁
Posts: 8,696 Likes: 415
Posts: 8,696 Likes: 415 |
With the higher screen is it necessary to have wipers? No you use this
Cheers Sid  just coz some of us are vertically challenged(short arsed in english)  (note to self; bite Cid's ankle next time we see him!!)
Posts: 1,370 Likes: 11
Posts: 1,370 Likes: 11 |
Thank you thank you thank you. I've used Rain-X on auto windows for the longest time but was completely unaware that they had formulated a silicone wax suitable for hydrocarbon based plastic.
This could be used on the Morgan, on poly-carbonate lenses, motorcycle helmet lenses and the like!
Turn signals!
Headlamps with poly-carbonate lenses like my JW Speaker LED lamps!
It boggles the imagination!
I'm agog
Posts: 213 |
I had one situation in very heavy rain where the fairbourne screen couldn't shed the rain fast enough, I had to look around the side and depend on my helmet visor to see, at a very slow speed. 2 lane road, no shoulder to pull over onto. Rain let up again after 5 or 6 minutes. I sealed the front bottom edges of mine using the masking tape method, and a popsicle stick. Worked very well.
Inge
Posts: 1,947 |
If you want the wider GT screen for hand protection but are shorter consider cutting down the taller GT. Mark your estimated upper edge with masking tape & trial fit it. Make a paper pattern before any cutting just in case.
Tim
