6 members (uvk33n, BLUE+4, Burgundymog, Barry M, Ritchie B, Deejay), 356 guests, and 69 robots.
+8Rich 86
Sagging Hood
Topics49,852
Posts837,444
kankeL #455298 15/06/17 01:13 PM
I agree about the water, they could rust out from the inside.
David cop
1997 Plus 4, Metalic Blue.
2000 Toyota Yaris. (The Tardis)
kankeL #455365 15/06/17 05:23 PM
Great mod Alex flag
kankeL #455377 15/06/17 06:24 PM
I would call them Jericho horns.
Tim
kankeL #455380 15/06/17 06:58 PM
kankeL Offline OP
Thanks for the feedback, guys!
Wolo makes protective covers which might help in really wet climates:
http://wolo-mfg.com/catalogsearch/result/?attr=0&q=cover
kankeL #456027 19/06/17 12:24 AM
[url=[URL=http://s1383.photobucket.com/user/johnmurray20/media/horn_zps839clbc6.jpg.html][/url]]horn[/url]
I have just bought one of these, do they need to be hooked up to a relay
rockabilly john #456036 19/06/17 05:53 AM
they need both relay and fuse, it's must have except if you have two good extinguisher in your car smile
rockabilly john #456041 19/06/17 06:49 AM
Not sure what current they take but highly recommended to use relay operated seperate fused feed, since the fuse feeding standard horn is only 7.5 amps, and not sure of current rating of horn switch.
This is how I wired my Nautilus Horn:
Removed original horn and extended wires to drive relay coil. Took main power feed from redundant intercom connection (purple/white wire) which was shortest run from fuse box. Fuse 18 (power socket/intercom) uprated from 15 to 20 amp as horn takes 17 amps.
kankeL #456109 19/06/17 03:14 PM
Kankel,
Nice work on the horns!
What are you using on your chrome to keep your pipes so clean and polished? I've been using Simichrome polish, but it takes a ton of elbow grease to keep the pipes clean and shiney.
Your chrome looks amazing! Even your headers look new!
polar993 #456177 20/06/17 12:27 AM
kankeL Offline OP
Originally Posted By polar993
Kankel,
Polar993, thanks for the compliment!
I was always a Simichrome fan but recently found this S100 product and it works very well on chrome/stainless steel and it is very easy to use: S100 Polishing Soap
The box lasts a long time. Highly recommend!
kankeL #456180 20/06/17 04:33 AM
Kankel,
Awesome! Thanks for the tip on the chrome polish....just placed my order!
