5 members (Pittsartist, TalkMorgan, banbury, Craig Jezz, JohnHarris), 214 guests, and 35 robots.
+8Rich 96
John V6 51
Topics49,901
Posts838,046
Just thought i'd put a little post up as might be helpful to some members.
As some might remember my last black 4/4 I decided to fit the black JW speaker lights from my land rover days left over. I thought about them again for this car, although decided they wouldn't suit it very well. So this time ive gone with a set of chrome Noldens. first impressions are very good, a great improvement on the originals, not sure there as bright as the speakers but more than make up for it in the looks department which is certainly less decisive!
Anyway heres a couple of pics to show them fitted;
Looks good .
Stefan
4/4
+8
ARP4
After looking into powerful uk headlights website and speaking to john v6 as he has fitted some I found out that bmw wiring will through up a warning light saying bulb blown due to wiring not accepting led headlights and wiring having to be changed and software needs to be re written on ecu ! Peter G has had everything changed on his plus 8 to allow fitting of the factory led headlights .
Formerly known as Aldermog
Indeed, the BMW wiring detects blown bulbs.
I have LED sidelights and fitting a 5W load resistor keeps the "BMW Brain" happy.
I test fitted the LED Headlights at Williams and there is sufficient load from the main and dip beam units to keep the "BMW Brain" Happy.
These are the LOAD RESISTORS I used...., just £9.99 from Halfords.
Those I like!
I was hoping to fit full LED headlights but after reading Peter G's comprehensive changes that need to be made I thought otherwise !
I think like Peter says for the traditional's the load must be enough as both the speaker and Nolden lights have been plug and play with no bulb failure lights coming up.
Hope this helps
Normal trads don't check for blown bulbs via canbus.
Nice to see them fitted I am interested in a set even more so now, as I do a fair bit of driving in the dark.
Mark - No Longer driving
I fitted the powerful uk units with LED sidelights on my CANBUS Plus 8. Fitted a resistor in the wiring but found that it got hot.
Solution? Keep the old side lamp bulb and leave it in the bowl behind the light unit, Simples!
1969 4/4
1995 plus 8
1996 Plus 4 4seater
2002 Aero S1
2013 M3W
2014 Plus 8
it's exactly why for me a Mog with can bus is out of question read
