0 members (), 416 guests, and 39 robots.
John V6 71
DaveW 67
+8Rich 65
9,208 Registered Users
Ozzy Osbourne
M3W - Anyone know this car?
by Biggle - 22/07/25 01:40 PM
Supermax sprocket
Morgan 3 Wheeler song
by Dutch - 21/07/25 12:31 AM
by Oskar - 20/07/25 04:13 PM
Topics48,341
Posts812,981
RedThree
comet Offline OP
Guys
My blue high beam symbol on the dashboard is always "on", does no matter whether the headlight is on high or low beam ...
What could be the reason?
Pete
in love with life. that's it.
E
E
Suggests a bad earth somewhere.
comet Offline OP
looking at the threewheeler from the outside, I realize one of the lamps isn't working properly (like 1/3 of full power).
could this also be a reason why the symbol always stays on?
Q
Q
Dissemble the light cover & see the connections
Could be a short between the high and low-beam leads, causing both to be on all the time. That may result in a back-feed that makes the high-beam indicator come on. As noted, I'd check to see if there is a short between the power leads to the two, or if the ground is bad. My guess is that when you disconnect the bad light, the indicator light will resolve.
