6 members (RubyMog95, Graham, G4FUJ, Montegue, Image, Biggle, MATTMOG),
296
85
Topics49,859
Posts837,477
Posts: 92 |
Do you notice any interaction between the noise and the engagement/disengagement of the clutch?
Posts: 149 |
If you haven't already remove the rear boot liner for a better visualization of everything in the rear from the top. Good idea....
Posts: 149 |
Do you notice any interaction between the noise and the engagement/disengagement of the clutch? No, I don't believe there is any correlation between the engagement of the clutch and this noise. It sounds as if something broke loose and is now rattling/clanking around over small bumps. It's a metal to metal sound.
Posts: 6,723 Likes: 2
Posts: 6,723 Likes: 2 |
I have about 500 miles on my 2016 M3W. I have been breaking it I slowly since the winter.
but I never had this noise until yesterday and it started soon after that initial clanking when I "banged" it into 2nd gear under full acceleration. I could be flippant here and suggest that the two quotes may have had a bearing on the noises..!! It's under warranty, get it to a dealer and let them look. If it means a breakdown truck, so be it.
Posts: 149 |
but I never had this noise until yesterday and it started soon after that initial clanking when I "banged" it into 2nd gear under full acceleration. I could be flippant here and suggest that the two quotes may have had a bearing on the noises..!! It's under warranty, get it to a dealer and let them look. If it means a breakdown truck, so be it. Steve, No offense taken to your comment. I admittedly did accelerate hard, and shifted quickly into second under full throttle. I used the word "banged" to describe the shift because the sound that occurred when releasing the clutch sounded as if something broke. I didn't pop the clutch nor was I driving the car in an abusive manner at all. I have a number of expensive vintage cars that I consider to be rather fragile and I drive them responsibly. I was doing the same in the M3W, and would never have expected to break anything with a fast shift into 2nd gear. I don't mean to come across as defensive...I just felt like an explanation was warranted. If it needs to be towed to the dealership, it's going to set me back about $300-400! Any other suggestions before I proceed down that route? (I will remove the trunk liner to see if I can notice any damage looking down from the top.) -Tom
Posts: 25 |
I have had this problem for about a month now whilst waiting for an appointment at my local dealer (Next Week). I have previously posted on another thread with a link to a video. Whilst I've been waiting I've made another video. This time I jacked up the car and turned the wheel by hand the "clank" appears to occur at the same point in the rotation of the rear wheel, after a number of rotations the point moves slightly forward. I'm thinking this may be a broken bearing. The belt is free of stones and so are the teeth. I'm rather disappointed now the nice weather has arrived I can't drive it. Hope this helps to identify your problem https://identifying.be/sl4M5dr6Eac
Posts: 1,338 |
I just saw the video on YouTube..maybe it's the bearing..if you try to remove the belt & test it again. So that you can cancel out if it's from the bevel box. It's very annoying I'm sure..nothing to do with the drum shoes?
Posts: 6,538 |
Try draining the oil in the Bevel box over a mesh filter- and check for any debris.
It could be a broken part of the Helical Gear??
Neil
Posts: 1,490 |
That fuel rollover valve behind the bulkhead can be VERY rattlley too. I tied mine tightly at a 45° angle with electrical ties to quiet it down.
The Original Ken 11,000 miles.
2014 BMW R9T 2005 Saabaru 2005 Saabaru
Posts: 25 |
It's apparently something to do with the brake drum the contents of which appear to have fallen off. After a 16 mile journey to the dealership the noise was a lot worse the drum was red hot. I'll post the final diagnosis when I have it.
