7 members (RedThree, mph, cerealsurfer, Gordon D, TalkMorgan, John Winn, TBM), 210 guests, and 92 robots.
Topics49,847
Posts837,389
Page 6 of 7 1 2 3 4 5 6 7
I ordered some M5 thumb screws off of Amazon today. I look forward to addressing this rattling issue this weekend. I find it a bit hard to believe that the rollover valve is creating this much noise, but I sure do hope this is my problem that needs to be resolved.
In case anyone needs to buy the screws. They are available through Amazon Prime.
Kipp 06090-05X16 Steel Knurled Thumb Screws with M5 External Thread, Metric, Black Oxide Finish, 16 mm Screw Length (Pack of 10) (Pack of 10) https://www.amazon.com/dp/B013IA7TQ6/ref=cm_sw_r_cp_api_z3YszbZDQZWRY
Another option from McMaster Carr
Plastic-Head Thumb Screws
Knurled, M5 x 0.8mm Thread Size, 10mm Long
Packs of 10
In stock
$6.25 per pack of 10
part number 96016A233
Lance
1981 Plus 8
2016 Three Wheeler
2022 Corvette Stingray Convertible z51
I am wondering if a new noise that just developed is from my rollover valve. During the drive, is it a chirping sound? Touching the valve with the car off sounds like a rattle, but yesterday from the back, I noticed a high-pitched chirp on and off while driving. 2300 miles and it just began.
Aka Joejoe
Do you have an Aluminium rear pulley, the chirping noise is the sort of noise you get with the drive belt and aluminium pulley.
2021 M3W
2013 M3W - Sold
1971 4/4 2 Seater
1934 Sports
Originally Posted By ArchieWetleg
It's apparently something to do with the brake drum the contents of which appear to have fallen off. After a 16 mile journey to the dealership the noise was a lot worse the drum was red hot.
I'll post the final diagnosis when I have it.
The Clanking sound turned out to be the End Float play in the bearing to hub fit. This required the replacement of the hub and bearings. The rear wheel was almost seized and the wheel cylinder was also replaced.
Thanks to Mike at Allon White for the excellent service and Phil for honouring the repair when just out of warranty.
Mine is steel, original to the car. 2016 build.
Aka Joejoe
Hi polar993,
How are things progressing with the clanking noise from the rear of your M3W?
Originally Posted By Sportster
Hi polar993,
I secured the rollover valve with tie wraps as seen in the photo below. I know it looks like I may have overdone it with the tie wraps, but it was the only way to minimize the rattling, and what I have done should not have any impact on the fuel lines or distribution. Please let me know if you think otherwise, and I should adjust what I've done.
Unfortunately while I may have eliminated the rattle from the rollover valve, I have not eliminated my "clanking" problem coming from the rear of my M3W. I still hear a sound that an area below/behind the seat that sounds like metal plates hitting one another. The sound is not constant, and it occurs when going over small bumps...most noticeably around turns. I feel when the weight of the car shifts from side to side on turns I hear the sound the most.
Could it be a cracked chassis??? That is my biggest fear!
The car does not seem "loose" or appear to feel different from day 1, but I have heard a few stories about how fragile the chassis is on the M3W, and I really hope mine isn't cracked!
I met up with Alex Roy a few weeks ago, and he told me he cracked two M3W chassis! Granted, Alex keeps his M3W in Manhattan, and is probably a bit rougher with it than most, but cracking 2 chassis....seriously, that sucks and is a big concern!
I haven't hit any major potholes, and I haven't been driving irresponsibly, so if I did in fact crack my chassis with my normal weekend driving, I would classify the chassis as being extremely fragile! Again, I really hope that's not the case but I guess the only way to find out for sure is to send the car to the dealership.
Ughh!
Have you checked the shock mounts to see if they are loose?
Lance
1981 Plus 8
2016 Three Wheeler
I did check almost everything in the drive train area, and nothing seemed out of sorts. Are there known issues with the shock mounts coming loose? Is it the top or the bottom of the shock mount that I should check?
