Posts838,002
Posts: 15,794 Likes: 15
Posts: 15,794 Likes: 15 |
Only just caught this- hope it's fixed quickly... +1 and does not prove too expensive! 👍 I guess the main cost is going to be labour: not sure if both wings have to come off, or just one. , a belt is £50 or so from BMW, the tensioner and idler wheels are reasonable prices. Only if it is the water pump, alternator or A/C compressor does it get really costly as Tom says that the belt and at 32k miles the tensioner should be replaced anyway, not re-used. More on this as it happens..
Posts: 38 |
Just fit an alternator to my series 1 not a bad job as long as you do not need to fully remove the bottom shock absorber Bol though hopefully Morgan have simplified changing shock absorbers by now PS bottom shock absorber mount may be something Sifab May want to re design
Well, problem solved...nothing expected! see my new thread.
Paul,
sorry, I missed your post. Yes, you were spot on!!
Not the easiest place to get at, so why the RHS wing had to come off.
