8 members (B3MOG, TBM, Doug J, Dek, MJF, Guern, Ian Wegg, Bunny), 223 guests, and 81 robots.
+8Rich 76
Topics49,861
Posts837,531
Jonny72
#457237 25/06/17 01:18 PM
Bish Offline OP
I've a near side front spot and rear fog not working. Checked bulbs and fuses, all are okay. Any pearls of wisdom. The car is a 1995 4/4.
Cheers
Bish'
Bish #457240 25/06/17 01:29 PM
Bad earth? Are the brackets (if forming the earth) clean/tight?
If there is an earth lead is this connected/clean/tight?
Bish #457243 25/06/17 01:45 PM
+1. Sounds like earthing
Bish #457244 25/06/17 01:49 PM
Bish Offline OP
Thanks I'll try that next
Bish #457252 25/06/17 02:42 PM
Bish Offline OP
Hi both, thanks earth it was.
Bish #457287 25/06/17 07:09 PM
Good result!
Considering the numbers of ageing( relative to ordinary cars) Morgans I think it is worth doing checks on the wiring. Several years of use with vibration, moisture etc builds up. Connectors can corrode/work loose. Hence poor earths in particular.
Earlier this year I had a wingtop sidelight fail on the 2002 car. . It was a corroded bullet connector. I replaced it with spades and sealed the joint. The joint was under the wing exposed to spray from the wheel. I did a change on the other side too as a precaution. 15 years/ 50k+ miles....no wonder!
The previous car was a1993 4/4. Earths failed causing starting problems. 17+ years for what looked like original cables/ fittings......no wonder!
Same for the fuel system......rubber flexi pipes for pre ethanol petrol, filters( lack of to protect the pump), mucky tank interior.....the 4/4 suffered from this but sorted fairly easily by flushing/replacing etc..
