5 members (sewin, Morganmike, Joske Vermeule, Adam12, +8Rich), 293 guests, and 40 robots.
Adam12 66
+8Rich 66
John V6 61
9,215 Registered Users
New
For saleWood rim moto-lita
by hugo - 30/07/25 04:28 PM
For Sale 2015 M3W - £23,000
by MOG42 - 29/07/25 06:28 PM
AC Cobra Rep. Vs Plus 8
Me Again
Tyre dates on Yokohama tyres
Aero 8 Maintenance
by mph - 29/07/25 09:24 AM
Moto-lita for sale
Moto-lita for sale
by hugo, July 30
2015 M3W for sale
2015 M3W for sale
by MOG42, July 29
Topics48,365
Posts813,374
Members9,215
Rbt Aero8, Salmon, stevends
Page 3 of 11 1 2 3 4 5 10 11
Not a small amount of money, but I would do it. That and a quieter sprocket, possibly.
Right now fitting a new cush drive, as the original, nippled one, disintegrated.
Trevor, who did the lapping?
M3W, now!!!
Originally Posted By DocNik
Why isn't it done at original manufacture?
The bevel boxes will be built to the lowest possible price and that will not allow lapping of the gears.
2021 M3W
2013 M3W - Sold
1971 4/4 2 Seater
1934 Sports
Back in February 2016 G56 posted this picture on Facebook with a comment "This is the disappointingly healthy looking insides of a noisy bevel box. 10 points, redeemable nowhere, to the person who guesses the cause of the problem correctly!".
I recently came across the post, and upon zooming in, was surprised to see the clear indication of a poorly adjusted gear set. The wear marks on the ring gear are right at the heel - to the extreme. A classic "HEEL CONTACT PATTERN" is concentrated off the heel end of the drive gear tooth. The solution is to move the ring gear closer to the pinion (decrease backlash) while maintaining minimum backlash.
Here is the zoomed-in image:
I'm curious if any other BBs have been disassembled to look at the developed wear pattern.
And no, G56 didn't respond to the post with any updated information...
Very interesting truck in.
As a non engineer would that not imply that the meshing is not correct?
When it should be?
Neil
Is there any description available on how to remove the bevel box?
Originally Posted By RoadsterBoy
... As a non engineer would that not imply that the meshing is not correct?
When it should be?
Yes and yes. Any shop manual on how to set up gears in a differential tells you how to read and adjust engagement and lash based on the gear engagement pattern. I just went and pulled my '65 Chevrolet Corvair shop manual, and scanned these two guides on gear wear:
Check G56's FaceBook posts, here is a link to their 40-sec video, more humorous than helpful:
Garage56 - fitting a bevel box
When it should be?
yes
Lance
1981 Plus 8
2016 Three Wheeler
2022 Corvette Stingray Convertible z51
The tbing is that without proper specifications I dont think I could kust remove it and have it properly shimmed.
kirkusblog.com
1952 Ford 8N
Perhaps - there is also the possibility that this is not even the real issue... It would be great for someone who has opened one up to weigh-in on this, or if someone could poke G56 to see what they have ruled-out or found. I posted a reply or two recently to their page.
