1 members (Cat302),
190
Goodwood
Topics49,928
Posts838,441
Posts: 8 |
There was a time when I got the dreaded shakes on hitting a pot hole at a certain speed but during a run yesterday it happened everytime I hit the slightest imperfections in road surface, any suggestions on how to cure much appreciated
Posts: 1,501 Likes: 5
Posts: 1,501 Likes: 5 |
What model car do you have??
Cheers,
Mark
1934 SS MX4 1938 Series 1 DHC 1951 Plus 4 2005 Roadster
Posts: 8 |
Hi Mark, I have a 1985 4/4
Posts: 5,447 Likes: 133
Black Rat Charter Member
Posts: 5,447 Likes: 133 |
Could be a shock absorber has failed
Posts: 8 |
Slightest imperfections in road surface was probably a bit of exaggeration but the shaking seemed to be more violent than in the past and quite honestly frightened the life out of me on the motorway. Previously I've managed to stop the shakes by adding a little power but this time had to decelerate and get on the hard shoulder
Posts: 1,943 |
Every time I get the "Malvern Dance" I find I have a tire problem. Damaged, out of round, not true, out of balance. Rarely alignment but I always check "toe in".
Button
How many miles? I have a 81 4/4 with 80K miles and recently changed kingpins and tires. Had a bit of a wobble prior. All good now.
Cheers,
Mark
Posts: 8 |
Yes just approaching 76k I'll get all suggestions of King pins and tyre conditions checked out and hope that cures. Many thanks, Richard
Posts: 163 |
Have you maybe lost a balance weight? Quite a common cause of a sudden change.
2008 Plus 4
Posts: 5,473 Likes: 173
Posts: 5,473 Likes: 173 |
I had a similar issue on our 1985 4/4 once. A look underneath found some loose nuts and bolts at the base of the king pin on one side.
Recommend a spanner check round the front end.
