0 members (), 275 guests, and 23 robots.
+8Rich 102
John V6 67
Goodwood
My 4/4 as it was in 1975
US Cars - Metric Threads?
by Paul F - 17/09/26 08:29 PM
Nice hardtop
International Morgan Day
by Deejay - 17/09/26 02:45 PM
2001 +8 Temperature gauge
by AlanB - 16/09/26 07:39 PM
Longest owner?
First Morgan as it is now
by Strathaven, September 15
Topics49,928
Posts838,441
Fuel.inj
#460093 09/07/17 01:51 PM
Rober51 Offline OP
There was a time when I got the dreaded shakes on hitting a pot hole at a certain speed but during a run yesterday it happened everytime I hit the slightest imperfections in road surface, any suggestions on how to cure much appreciated
Rober51 #460094 09/07/17 02:10 PM
What model car do you have??
Cheers,
Mark
1934 SS MX4
1938 Series 1 DHC
1951 Plus 4
2005 Roadster
Rober51 #460095 09/07/17 02:13 PM
Rober51 Offline OP
Hi Mark,
I have a 1985 4/4
Rober51 #460097 09/07/17 02:27 PM
Black Rat
Black Rat
Could be a shock absorber has failed
Keith
2013 narrow bodied + 4 Ruby.
Rober51 #460099 09/07/17 03:07 PM
Rober51 Offline OP
Slightest imperfections in road surface was probably a bit of exaggeration but the shaking seemed to be more violent than in the past and quite honestly frightened the life out of me on the motorway. Previously I've managed to stop the shakes by adding a little power but this time had to decelerate and get on the hard shoulder
Rober51 #460100 09/07/17 03:15 PM
Every time I get the "Malvern Dance" I find I have a tire problem. Damaged, out of round, not true, out of balance. Rarely alignment but I always check "toe in".
Button
Rober51 #460102 09/07/17 03:20 PM
How many miles? I have a 81 4/4 with 80K miles and recently changed kingpins and tires. Had a bit of a wobble prior. All good now.
Cheers,
Mark
1934 SS MX4
1938 Series 1 DHC
1951 Plus 4
2005 Roadster
MarkB #460106 09/07/17 03:30 PM
Rober51 Offline OP
Yes just approaching 76k I'll get all suggestions of King pins and tyre conditions checked out and hope that cures.
Many thanks,
Rober51 #460126 09/07/17 04:35 PM
Have you maybe lost a balance weight? Quite a common cause of a sudden change.
2008 Plus 4
Rober51 #460141 09/07/17 05:34 PM
I had a similar issue on our 1985 4/4 once. A look underneath found some loose nuts and bolts at the base of the king pin on one side.
Recommend a spanner check round the front end.
Costock, UK
Disco 5
