Topics49,844
Posts837,355
Posts: 5,013 Likes: 32
Posts: 5,013 Likes: 32 |
Just as an update - and as B&C suspected when I met with them at Goodwood - there is a leak on the pipework connecting the oil cooler to the engine.
In some ways I'm pleased it's not the sump as it would have meant I had given it an almighty clout and not have felt it!
Not sure when I will get the car back. Soon I hope as it's the Season.
+8 4.8
Posts: 5,654 Likes: 4
Posts: 5,654 Likes: 4 |
Guess that's good news as fairly easy to fix.
Martin (Deano)
Posts: 5,587 |
Not sure when I will get the car back. Soon I hope as it's the Season. Do you think it was caused by something catching it from underneath or a faulty hose clip ?
B&C advise that two hoses were rubbing together and have eventually split. I am not sure if a clip to keep them apart is missing. I suspect this is a one off and not a feature of every 4.8 V8.
+8 4.8
I suspect this is a one off and not a feature of every 4.8 V8.[/quote] Possible the result of craftsmen at work
Martin (Deano)
Posts: 5,587 |
When I get my lift installed I would like to think I can keep an eye on whats underneath as well as tidying things up eg clips/pipes etc and cleaning the side pipe boxes.
Guess that's good news as fairly easy to fix. You'd think so. Still off the road.
+8 4.8
Guess that's good news as fairly easy to fix. You'd think so. Still off the road. No way: whats the issue?
Martin (Deano)
Slow response from factory and then the wrong parts sent.
+8 4.8
Posts: 22,356 Likes: 353
Posts: 22,356 Likes: 353 |
Slow response is the Morgan way. I had an experience in 2013.
Stand up and points to the board. The whiteboard.......... Three C's. Concern Cause Countermeasure
The pacesetter way.............
If nothing changes it hasn't been identified as a concern. Which is a concern.
