7 members (IcePack, MATTMOG, mph, John07, Sloany, +8Rich, JohnHarris), 290 guests, and 41 robots.
John V6 70
DaveW 66
+8Rich 66
9,208 Registered Users
Ozzy Osbourne
M3W - Anyone know this car?
by Biggle - 22/07/25 01:40 PM
Supermax sprocket
Morgan 3 Wheeler song
by Dutch - 21/07/25 12:31 AM
by Oskar - 20/07/25 04:13 PM
Topics48,341
Posts812,992
RedThree
60.000km past and always the original bearing, I own two bearings new spare brand NTN in case I get to the worn I wash only my tw with hose and watering the rain.
Can someone post the bearing specifications and/or replacement model numbers to help others order replacement in advance of a failure? If we need them at some point, would be a easier to grab the replacements from your personal parts shelf than start the hunt for a proper replacement.
comet Offline OP
OK. I have the confirmation, its the bearing.
and the bearing was left with 4 balls only!
in love with life. that's it.
Sounds like you caught it just in time and hopefully it'll be a quick fix.
Red Leader drive
comet Offline OP
hope so!
the m3w meeting is in approx. one month and everything is booked and paid!
Shamelessly copied from previous posts:
The bearing sizes are 52mm OD, 25mm ID and 15mm width and have rubber seals on both sides. Have a look on: http://www.bearing-king.co.uk/ . They have information on sizes and specifications. Something like SKF 6205-2RSH or 7205 if you want go for a higher specification (and cost). The ones on my car just had "made in china" stamped into the housing, so I don't think they are anything special. Raphy (Atlante83) has some more part numbers and information for replacing these bearings I think. You will need a C3 ID clearance so the axle can be removed without a press.
The best are: FAG 7205-B-2RS-TVP (available from Bearing King in the UK)
Andy
comet Offline OP
fyi
the complete rear axle has been replaced.
it will be sent to Malvern ...
Pete
