Morgan Aero 8
1 members (Mogdavid), 303 guests, and 57 robots.
+8Rich 86
by stumog - 26/08/26 10:24 AM
Topics49,844
Posts837,360
Christoph
Page 8 of 9 1 2 3 4 5 6 7 8 9
Just as an update - and as B&C suspected when I met with them at Goodwood - there is a leak on the pipework connecting the oil cooler to the engine.
In some ways I'm pleased it's not the sump as it would have meant I had given it an almighty clout and not have felt it!
Not sure when I will get the car back. Soon I hope as it's the Season.
+8 4.8
Guess that's good news as fairly easy to fix.
Martin (Deano)
Do you think it was caused by something catching it from underneath or a faulty hose clip ?
B&C advise that two hoses were rubbing together and have eventually split. I am not sure if a clip to keep them apart is missing. I suspect this is a one off and not a feature of every 4.8 V8.
+8 4.8
I suspect this is a one off and not a feature of every 4.8 V8.[/quote]
Possible the result of craftsmen at work hide
Martin (Deano)
When I get my lift installed I would like to think I can keep an eye on whats underneath as well as tidying things up eg clips/pipes etc and cleaning the side pipe boxes.
You'd think so.
Still off the road.
+8 4.8
You'd think so.
Still off the road.
No way: whats the issue?
Martin (Deano)
Slow response from factory and then the wrong parts sent.
+8 4.8
Slow response is the Morgan way. I had an experience in 2013.
Stand up and points to the board.
The whiteboard..........
Three C's.
Concern
Cause
Countermeasure
The pacesetter way.............
If nothing changes it hasn't been identified as a concern.
Which is a concern.
