2 members (MartinB60, sprinty),
243
42
Posts837,992
Posts: 775 Likes: 33
Posts: 775 Likes: 33 |
See pics in post below. These are Bontrager Flare R Tail Lights made for bicycles, $60 U.S. each. They use very bright Cree LED bulbs. Visible up to 2 km. These are very visible. The electronics allow for continuous daylight, continuous nighttime, flashing daylight, and flashing nighttime modes. I'm going to use the continuous daytime mode since two flashing lights at distance will look like a police vehicle. Waterproof construction. Lights are easily detachable from support bracket and batteries are rechargeable. USB cable supplied for charging. The elastic rubber strap isn't quite long enough to wrap around the roll bars so I used a black plastic zip type strap to help secure them, worked well. These can also be easily removed if desired.
I keep my rear fog visibility light on all the time as well.
Posts: 1,544 Likes: 1
Posts: 1,544 Likes: 1 |
I would put them on outside of hoops give sense off how wide we are
Posts: 99 |
TimG, You are spot on!!!! THANKS!!! I ordered two packs of these inexpensive bike lights that come one red and one blue in one pack for around $11.00. I had to trim the rubber base area just a little on one side as they are made for a angled handle bar. They are continuously on, flashing, fast flashing and off. Seem quite bright. I stuck the blue ones forward and they seem bright as well. I like a higher light on the roll bar and can have these on in just seconds with the soft rubber strap for a late night drive. In heavy traffic or these steep hills and deep foggy valleys it may just save your life! [img:center]  [/img] [img:center]  [/img] [img:center]  [/img] High Noon My Blog: https://ontheroadtonowhereville.wordpress.com/
Posts: 423 Likes: 2
Posts: 423 Likes: 2 |
Illegal to run blue lights here in Georgia
Lance 1981 Plus 8 2016 Three Wheeler 2022 Corvette Stingray Convertible z51
Posts: 99 |
Thanks Lance ...oops better just run the red ones when needed and use the vintage fog lamps up front!
You can still stick one on and use as an interior light....is cool looking...or better yet turn them on to flashing when behind a friend!! ....lol
High Noon
Posts: 836 |
Illegal in Florida as well.
Rears look fantastic!
Posts: 1,569 Likes: 12
Posts: 1,569 Likes: 12 |
Illegal to run blue lights here in Georgia And in the UK
Steve L.
1996 Plus 8 N22 MOG
Posts: 2,822 Likes: 155
Posts: 2,822 Likes: 155 |
