3 members (TBM, deano, Vansrv6), 175 guests, and 26 robots.
+8Rich 100
John V6 66
Clutch for a 1982 4/4
DVLA frustration.
Old Book
by Pundit - 21/09/26 01:39 PM
Factory meet
Mog Mags
by Lord Sward - 20/09/26 01:44 PM
First Morgan as it is now
by Strathaven, September 15
Topics49,937
Posts838,564
greenteagod
DaveW Offline OP
No time to post pictures today, because I've just got in a after a full day on the springs. The old one came off easy enough and when compared to the new has significantly less camber unloaded - it really has flattened out. It's been of great benefit to get the car ready before starting on the hard work though. I've covered the new springs with Denso tape, and I'm really pleased with how this has gone on, although you have to be careful when fitting the spring, because it's quite easy to pull the tape out of line. Before doing that I slackened the centre nut and first dribbled ep90 between the leaves, then later chain grease, before wrapping. Today I only had time to do the offside because it was a fight all the way. The rear shackle is very hard to access, and with a well cambered spring, it must be compressed about 2" to locate the bolt. What makes it worse is that there is a washer each side of the shackle which is very tricky to relocate. So that took a lot of time, but the other side should be easier tomorrow. The axle U bolts were not too bad, easier than the MGB, but access is terrible. For the front shackle pin, I used a couple of G clamps on the front of the spring and that worked quite well. This is hard work and I'm ready for a snooze. Pictures will follow when I get time.
Look forward to learning more as ever Dave.
DaveW Offline OP
Post Photobucket Reboot.
Unfortunately this batch of images were not backed up, and so can't be replaced.
Its odd that they were deleted, but there you go. These things happen.
ooo
For the front grease nipple on the propshaft UJ you need a Sealey 170mm Needle Nose Grease Gun (very cheap on Ebay). Clean off the nipple, fit the needle gun to your regular Wanner-type grease gun and hold it hard into the nipple hole while pumping. This makes doing the front U/J the work of minutes (assuming you have a lift) and does not require any cutting of floorboard or trans tunnels.
