0 members (),
247
40
Topics49,911
Posts838,152
Posts: 22 |
[img] http://tinypic.com/a/abnz1v/4[/img] See images above. Temp gauge is normally halfway between 90 and 140 degrees. When stuck in traffic it goes closer to 140. Seems consistent so I think its a gauge issue. Plenty of coolant - no leaks. Any ideas? Ive got a 300km drive in it tomorrow so that should really test it. Thanks. Dreamon
Dreamon. 1987 4/4 2-seater 1.6 CVH
Posts: 5,587 |
Having had temp issues on old classics a temperature measuring device that is pointed towards the offending area and trigger squeezed to get a reading is a very useful bit of kit , need to buy one really !
Posts: 7,553 Likes: 88
Posts: 7,553 Likes: 88 |
Is the fan cutting in? If not, check the relay.
Bud 4/4 "Stanley"
Posts: 37,489 Likes: 993
Posts: 37,489 Likes: 993 |
I would suspect the instruments voltage regulator as from what you have said the temperature is not that indicated on the gauge.
Posts: 163 |
My (former) 1992 plus 4 used to sit at about 90 and then rise when in traffic until the fan cut in, then the temperature dropped until the fan stopped. Your Ford engine will clearly have different temperatures shown as the thermostat temperature will be different but I would expect similar behaviour with no air flow through the radiator.
2008 Plus 4
Posts: 5,442 Likes: 133
Black Rat Charter Member
Posts: 5,442 Likes: 133 |
I spent two years and a considerable amount of money chasing an overheating problem on my V6 Alfa Spider until I spent £12 on a infra red temperature gun and realised it was the gauge
Posts: 898 |
Either go into Maplins or if you have time Ebay and search for IR thermometer.
Posts: 238 Likes: 3
Posts: 238 Likes: 3 |
Remove the temperature probe from the engine , with it still connected to the gauge and ignition on put it in a large container of boiling water to determine if the gauge is reading correctly, if it is . It then means you have an issue with the cooling system . Which I would start by checking the thermostat., as a short stop measure you could wire in a fan cut in bridging switch.
1999 Morgan Plus 8. 3.9 .... 1961 Alvis TD21 Series1 3 Litre Auto....
Posts: 1,616 Likes: 143
Posts: 1,616 Likes: 143 |
Following on from Smudgers post, have you changed the temperature sender? On the crossflow engined cars, the standard Ford sender is not compatible with the Smiths instruments and gives all sorts of readings!
Arwyn
Posts: 28,912 Likes: 354
Posts: 28,912 Likes: 354 |
 It's CVH engine Arwyn, but I think the same applies re: temp sender?
