4 members (+8Rich, Hamwich, Chris Cosher, RichardV6), 233 guests, and 75 robots.
+8Rich 76
Oil level reading
by moggin - 05/09/26 01:58 AM
Topics49,877
Posts837,713
Page 85 of 94 1 2 83 84 85 86 87 93 94
drk #466061 11/08/17 05:19 AM
DRK. I paid £970 +vat for the Centa drive assembly and £377+vat for the clutch kit (excluding labour) probably the best "upgrade" you can do on a 2012 the difference is very noticeable,if you say such a thing about a M3W it's smother.so all in all I think it's worth the cash.
Q8morgan #466167 11/08/17 01:46 PM
O
O
Dear Q8 why haven't you considered doing the service at Dubai Morgan Dealer ?
Anyhow i wish you a safe and pleasant trip to Portugal and Spain. And I hope to run in to you if you are ever in Marbella area.
Take care thumbs
Osama #466485 12/08/17 10:18 PM
Q
Q
The factory has more experience And I want to use it Portugal.
Q8morgan #466488 12/08/17 11:19 PM
Don't forget Mario lives down there will you, he hillclimbs his M3W and Plus4.
Elcyd #466532 13/08/17 09:17 AM
O
O
Is this Centa Drive problem solved on later models? i.e. 2017? I yet have to receive my M3W later this year and hope Morgan has sorted these problems by now?
Osama #466540 13/08/17 09:51 AM
Yes, it is standard from the 2014 model year onwards
Red Leader drive
Q8morgan #466558 13/08/17 12:03 PM
Charlie, Former Editor
Mi3Wheeler #466576 13/08/17 04:00 PM
Q
Q
With the centra drive i should still keep the rpms high? Not too high but like 25%
Q8morgan #466579 13/08/17 04:37 PM
Seems happiest between 2800 and 4500 rpm.
Q8morgan #466624 13/08/17 07:50 PM
S&S recommends keeping the motor above 2700 rpm on bikes. Most of the bikes come in at around 750lbs. The M3W starts at 1200 lbs. With the added weight I'd try to keep the motor above 3000 rpm just to be safe. You can feel the torque spikes until 3700 rpm then it smooths out. The torque peaks at around 3300 rpm? I don't think the Centa unit is robust enough. Many of the couplings like this are made for constant speed pumps and generators. This car clearly does not fall into that catagory. The transmission was made for a car that could go from 1000 to 7000 rpm. Our effective range is from 3000 to about 4700 rpm. There are gaps. So we have holes where you're lugging the motor or pushing the revs hard with some areas of sweet spots joining them. Then there is reverse! I just cracked the frame on my 2012 with the added brace. The motor is clearly too powerful for the frame and the Centa unit. Take care.
