7 members (RubyMog95, SteveT, Tom Sayles, IcePack, mph, Morganmike, gomog),
315
84
Topics49,872
Posts837,704
Posts: 103 |
DRK. I paid £970 +vat for the Centa drive assembly and £377+vat for the clutch kit (excluding labour) probably the best "upgrade" you can do on a 2012 the difference is very noticeable,if you say such a thing about a M3W it's smother.so all in all I think it's worth the cash.
Posts: 66 |
Dear Q8 why haven't you considered doing the service at Dubai Morgan Dealer ? Anyhow i wish you a safe and pleasant trip to Portugal and Spain. And I hope to run in to you if you are ever in Marbella area. Take care
Posts: 1,338 |
The factory has more experience And I want to use it Portugal.
Posts: 37,437 Likes: 983
Posts: 37,437 Likes: 983 |
The factory has more experience And I want to use it Portugal. Don't forget Mario lives down there will you, he hillclimbs his M3W and Plus4.
Posts: 66 |
Is this Centa Drive problem solved on later models? i.e. 2017? I yet have to receive my M3W later this year and hope Morgan has sorted these problems by now?
Posts: 3,732 Likes: 79
Posts: 3,732 Likes: 79 |
Is this Centa Drive problem solved on later models? i.e. 2017? I yet have to receive my M3W later this year and hope Morgan has sorted these problems by now? Yes, it is standard from the 2014 model year onwards
Red Leader
Posts: 1,664 |
Charlie, Former Editor Morgan Owners Group - Great Lakes
Posts: 1,338 |
With the centra drive i should still keep the rpms high? Not too high but like 25%
Posts: 1,664 |
Seems happiest between 2800 and 4500 rpm.
Posts: 1,370 Likes: 11
Posts: 1,370 Likes: 11 |
S&S recommends keeping the motor above 2700 rpm on bikes. Most of the bikes come in at around 750lbs. The M3W starts at 1200 lbs. With the added weight I'd try to keep the motor above 3000 rpm just to be safe. You can feel the torque spikes until 3700 rpm then it smooths out. The torque peaks at around 3300 rpm? I don't think the Centa unit is robust enough. Many of the couplings like this are made for constant speed pumps and generators. This car clearly does not fall into that catagory. The transmission was made for a car that could go from 1000 to 7000 rpm. Our effective range is from 3000 to about 4700 rpm. There are gaps. So we have holes where you're lugging the motor or pushing the revs hard with some areas of sweet spots joining them. Then there is reverse! I just cracked the frame on my 2012 with the added brace. The motor is clearly too powerful for the frame and the Centa unit. Take care.
