1 members (tommog), 223 guests, and 72 robots.
+8Rich 82
Topics49,849
Posts837,425
Page 1 of 4 1 2 3 4
DaveW Offline OP
On 30th August 2008 I picked up my Roadster. I've learned quite a lot in the nine years which have followed. I didn't like the open front aspect of the Trad (still don't), but back then I wouldn't have contemplated bending aluminium of the required size. So as some of you will know, I adapted an MGB spoiler to fit the front, and this, with a flat aluminium tray between the over-rider brackets, has served me well.
In 2013 when we bought Mr Bumble, I still lacked the confidence to make a one piece valance, but managed a short valance which attached to the flat tray between the over-rider brackets. It wasn't until 2016 and The Plus 4 that I got stuck in with a full length valance, which turned out well. And so this became my next Roadster job.
Starting with a sheet of aluminium. The Roadster over-rider brackets are fitted with the horizontal ledges facing inwards, unlike Tigger where they face outwards, so immediately the two valances are different.
Before I got this far, here's the radiator, which needed a good clean.
After cleaning. and with a light blow over of satin black. I also couldn't resist adding a cosmetic carbon fibre trim over the bottom panel. Note the Rivnuts which attach the grille. I refit the setscrews from behind for convenience and here they are wound in. They are much longer than this. Newer Morgans don't have Rivnuts. They have simple holes drilled in this panel. The holes may be enlarged to get a good fit to the grille.
Neil asked how I get my number plate box more vertical. This is how. Not very elegant, but effective.
This is the beginning of the bending...............
And the first test fit..........
This is one of the side panels. Because they are small, they bend easily and uniformly.
Here are the side panels, shaped and drilled.
And here's the main valance, shaped and drilled. The six holes in the top left corner are to allow air to get in to reach a sensor which is located on the lower cross tube.
This was the end of day 1. About four hours work.
More to follow....................................... thumbs
Great work as usual Dave . laugh2
Thanks for the tip,on the number plate - it really irritates pointing to the sky! swear
Even I can give that a go! laugh2
Neil
DaveW Offline OP
The next day was a test fit of the neoprene edging.
Bespoke brackets were needed for the end pieces. Starting with cardboard, and finishing with these.
This is how they fit, using existing holes.
Porsche Signal Orange from the seventies was on my short list of two colours for Tigger. I didn't have the guts to go for it, but I did have an aerosol can, So I used it for the first two coats, just to see....................
I must admit to feeling a twinge of regret. It looks fantastic.
This is the start of the top coating..............
Flatted off...........
Finally with lacquer. Painting at home isn't easy. Sometimes it's two paces forward and five back, and red is much harder to get right than yellow. But in the end, it's acceptable, but certainly not professional standard!
More to follow..................... thumbs
It all looks good to me Dave!
Well done ..as usual!
Neil
DaveW Offline OP
Now with neoprene edging added...........
This is how it looks with the number plate box removed and no undertray.
This is how it is cut around the over-rider brackets.
Now with number plate box added.
And that's it! Quite a few days work. The shaping went really well, but the paint was a real problem to get right this time, but where do you stop re-doing it!!!!!
Although this may be beyond the ability of some owners, there are metal benders out there who could easily make one of these trays, but would need your car for the fitting. And it could be sprayed professionally. But the two I've made are completely different, and so can't be interchanged.
Finally I have the old flat aluminium undertray which is available if anybody is interested, as a simple bolt-on between the over-rider brackets. Your brackets MUST have the horizontal ledges facing inwards, unless you are prepared to swop them round, which means splitting the track rod ends. Dimensions are 310mmx660mm. Fastener spacing is 150mmx640mm, which should align with the predrilled holes in the over-rider brackets. Send me a PM for more details.
The spoiler is also available with all fittings, but will need some gel coat repairs and a full repaint. The neoprene edging has perished and so than also needs replacing. I might pop this on e-bay, at 1p rather than bin it!!
thumbs
Masterpiece delivered again!
Is this a Mark II or III?
I admire your skills and determination.
Bert
2025 Plus Six - 1909
2009 Roadster
1983 4/4 4str
DaveW Offline OP
2005 Bert so Mk1, or Series 1.
That is top work Dave. The paint looks good from here.
Cheers
Spectacular.....
I am trying to make covers for the rocker/threshold out of T-16 aluminum. Trying to get rid of water absorbing horse hair/vinyl etc. T-16 is not bending easily. So I am heating (annealing) so I can form it. Very slow at the moment. Any suggestions would be helpful. I know buy plastic ones from "Black Phaeton".
Button
Page 1 of 4 1 2 3 4
