5 members (Image, JMcL, cerealsurfer, RichardV6, RedThree), 309 guests, and 22 robots.
+8Rich 91
John V6 49
Posts837,985
E
E
Hi,
I have a pin prick leak on the visible edge of the radiator head. It is so small that even at running temperature with the system pressurised it just drips. Its very accessible and about an inch to the right (looking forward) of the main pipe that runs from the radiator to the stainless steel pipe that is along the top of the engine.
See photo.
I have tried RAC permanent rad sealer but it has not worked. The leak is so small I believe a putty might work. Can any one suggest a good product.
Also bearing in mind I am in Witney (OX29 6PZ) can any body recommend someone who could braze the hole insitu without having to remove radiator from car?
Any help appreciated
Ian
Permatex has a rad putty.
http://www.permatex.com/products/special...tor-repair-kit/
I have used it and it works for small leaks.
Cheers,
Mark
1934 SS MX4
1938 Series 1 DHC
1951 Plus 4
2005 Roadster
J B weld. Worked a treat on our leak
E
E
Mark and Lachlan. Hamwich thanks for sorting picture. i did get there in the end. Thanks. Ian
