5 members (deano, Vansrv6, rory kim, Graham, G4FUJ, SCX358G), 192 guests, and 31 robots.
+8Rich 100
John V6 66
Clutch for a 1982 4/4
DVLA frustration.
Old Book
by Pundit - 21/09/26 01:39 PM
Factory meet
Mog Mags
by Lord Sward - 20/09/26 01:44 PM
First Morgan as it is now
by Strathaven, September 15
Topics49,937
Posts838,564
greenteagod
Page 4 of 4 1 2 3 4
Nice work as ever Dave. Like the "warning triangle".
DaveW Offline OP
Post Photobucket Reboot...........
I remember that when I made the wooden tool tray for my Roadster that it was a challenge, and I nearly gave up.
And so it happened again yesterday when I was on the edge of giving up...................
This time though the raw material was aluminium. I pondered this for a while, whether to go for wood again, of a mix of wood and aluminium, or full aluminium. Clearly aluminium gives a bit more depth than wood which has to be thicker for strength.
So first I tried my wooden cap piece for size.
This method was the basis for the Roadster wooden tray, but in the end I decided to try a single aluminium panel, so I didn't use this piece of wood. The aluminium chosen is 1.2mm thick and quite a challenge to bend on a large piece.
This is how it started. I had to run the Morgan onto that piece of wood to hold the aluminium down so that I could bend it. The remainder of the bending was either in the vice or hammered over wood.
The edges were turned over to provide a flange to attach the sides to, and to give rigidity.
38" is the maximum width.
These measurements were the basis of the cut out for the diff, but the hole was extended to the right as the diff housing is offset.
Initial fit. A protruding bolt in each rear corner makes it a tight fit.
It was at this point I nearly gave up, because it had been really hard to get this far.
Then I removed the protective film............ grin2
Next came the side panels. There's really only one way to do this without a fancy cutter........
UPDATE - note that I later replaced these tin snips with some much better items.
More to follow.............
DaveW Offline OP
Post Photobucket Reboot.............
After the sides had been cut, bent and fixed in place (DS tape and nuts/bolts) - Next a trial fit with the sides in place:
I kept this tray symmetrical (except that the hole for the diff is offset). The wooden version has a deeper section on the offside as there's a bit more vertical room, but with aluminium..............
The next job was to mock up a cardboard template for the diff housing.
Many minutes of tinsnip work later:
Bending in progress:
Fitted - DS tape and nuts/bolts again. I reinforced the front edge with some L section aluminium (Wickes).
Finally this afternoon - I've glued some O section neopreme along the edges, which should prevent any leakage from underneath. On the rear edge you can make out one screw head, there are two screws into the rear frame, and on the front I've added a bracket and there are two nuts and bolts, one either side of the centreline, mainly to prevent rattles.
And here's the cover in place. The yellow 'rope' came from a torch.
This is not the end, because I need to finish off the underside, and line the tray with neoprene, so there will be a final instalment next week hopefully.
A word of warning though - unless you have steely resolve, and are competent in forming metal, don't attempt this at home. It looks easy but it's one of the hardest jobs I've done.
DaveW Offline OP
Post Photobucket Reboot.................
Finished off today..............
First the neoprene:
Then the tools. There's more room with this one than with the wooden version. Bags of room in fact.
Very pleased with the outcome!
DaveW Offline OP
Post Photobucket Reboot......................
A few more pics from below, taken today.
Offside, looking up! I had to hammer a slight bulge to clear the damper tops and covered it with neoprene just in case there was contact, but it's OK. I used a ball pein hammer over a large socket...............
Nearside: This also shows handbrake adjuster.
This shows the padded cover for the diff case:
Note also the 'bump stop' on the tube in case the diff deflects that far up. To the right is my stainless bracket which holds the tool tray at the front.
I lined the inside of the battery hatch with green camping mat - visible here:
And here you can see the neoprene flap I fitted at the base of the battery hole - to stop road dirt splashing up. You can also see my battery charger in-line fuse!
Finally I bought this from my local garage about five years ago..............it's the size of a fancy phone,
But unzips into this, with four suckers if required.
Its reflective and if stuck on a dark road, might just make a difference. No makers name or any reference on it though. It was about £2 as I recall.
That's all. thumbs
Page 4 of 4 1 2 3 4
