Morgan Aero 8
6 members (CJB, B3MOG, MJF, sbarracl, Bishmog, WR142LLJPN), 355 guests, and 109 robots.
+8Rich 77
Topics49,868
Posts837,640
Moggo
Page 2 of 4 1 2 3 4
Michael #470227 02/09/17 12:41 PM
madmax #470230 02/09/17 01:02 PM
U
TM Photographer of 2008
U
Originally Posted By madmax
How would this help? The OP's car has an isolator which he doesn't want to use as its use requires the windows to be reset. crazy3
Ken
Michael #470231 02/09/17 01:14 PM
My aero 8 is 2016 and still on its original battery. I just use a trickel charger. Problem solved.
Martin (Deano)
Michael #470236 02/09/17 02:23 PM
Change car for a 4/4....problem solved !!!!
Sorry !!!! hee hee
E
E
Originally Posted By milligoon
Battery ideally should be matched to the alternator.
I think this is some what wrong.
Are you inferring that going from say a 58 AH battery car battery to say a 70AH or going mad an 80 AH car battery will cause a problem as the Alternator will not be able to charge it!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Michael #470297 02/09/17 08:21 PM
It won't cause a problem.
It's just that it'll take longer to fully charge the bigger battery, so once the battery gets to a similar state of charge to the original, if the car is infrequently used yet the car has a constant drain when not in use then the alternator when the car is used will only charge up the bigger capacity battery to the same state of charge as the lower capacity battery.
HA! you say. I can charge it up when not in use! In which case what is the point of paying more for a bigger battery when you could have charged up the original spec battery when not in use.
The problem with these cars are not the batteries or the alternators, it's the car electrics sucking the life out of the battery when not in use.
I had a Volvo that was able to sit unattended for 3+months with no detrimental effect on it's battery serviceability.
There is no point upspeccing the battery they shouldn't be facing such continuous drain when the car is parked up.
Mark - No Longer driving
Peter J #470363 03/09/17 09:12 AM
Michael Offline OP
Originally Posted By Peter J
The battery in Tarka is from mid 2013, according to the sticker. It will last for about 2 weeks without the trickle charger, but if the radio is left on the battery goes flat over night.
How do I know this, yes, I found out the hard way.....
As has been said, a larger battery, if beyond the capacity of the alternator, won't help.
A trickle charger is the cheapest solution, I feel.
My thinking was, if the more powerful battery is fully charged by my ctek before setting of on a trip surely the alternator will keep it topped up and in any event it should take longer to be drained while parked up?
Michael
Michael
Aero 8 S4
uvk33n #470365 03/09/17 09:18 AM
Originally Posted By uvk33n
For back-up whilst travelling get one of these or similar.
There are cheaper versions of similar things, but yes, this is what I would do. Swap the battery for like for like and keep on a trickle when it's in your garage at home.
+8 4.8
Neilda #470370 03/09/17 09:50 AM
U
U
Yes, I paid £30 for mine but it wouldn't have the grunt to start an Aero.
Ken
Michael #470372 03/09/17 09:55 AM
+8 4.8
Page 2 of 4 1 2 3 4
