Morgan Aero 8
9 members (CooperMan, Neville1, Cerberas, Pittsartist, JMcL, RichardV6, Craig Jezz, MartinB60, GrumpyPa), 321 guests, and 128 robots.
+8Rich 75
Topics49,869
Posts837,659
Moggo
Page 3 of 4 1 2 3 4
Michael #470373 03/09/17 09:57 AM
Michael,
No idea if they're any good, but might a solar trickle charger plugged in via cigarette lighter socket do the trick when you're travelling?
Cheers
Philip
1985 Plus 8 four seater
Malone F1000 - track car
Michael #470386 03/09/17 11:20 AM
Michael Offline OP
I'm very confused now!
I simply think if I go away for 7-10 days and park my Aero outside in a hotel car with little or no use, I will Not be confident the current spec battery will hold up so surely a higher capacity battery will take longer to go flat solving my concern.
I have all my cars on trickle Ctek chargers at home.
Michael
Aero 8 S4
Michael #470387 03/09/17 11:22 AM
A new battery should last at least a couple of weeks... however, take a jump pack... if it goes flat, then you can start immediately. smile
+8 4.8
Michael #470433 03/09/17 04:20 PM
mph Offline
You're quite right.
Fit a larger capacity battery and you'll be able to leave the car idle for a longer period without suffering from a flat battery.
There are some very high performing batteries available, but of course they're more expensive. Example ..
https://advancedbatterysupplies.co.uk/agm-batteries/
https://www.consumerreports.org/cro/car-batteries/buying-guide
Michael #470456 03/09/17 05:56 PM
fit an Odyssey battery *, keep it on a Ctek trickle charger and get a battery booster/jump starter pack for when it's been standing a while when away from home thumbs
* http://www.demon-tweeks.co.uk/motorsport/batteries/odyssey-extreme-racing-35-battery-pc925
James
RR Evoque P300E Autobiography
Smart Brabus Convertible
Monkey Z125
Michael #470471 03/09/17 06:51 PM
I do have a red isolator switch on my S4 in the engine bay but I don't want to use that as I then have to reset windows when powered back on, I keep all my cars on a ctek but my battery drains quite quickly if not used and I am planing trips where we won't have access to charging and in the autumn stood in hotel car parks may test the battery.
My thinking is not the overall life of the battery but how long it takes to drain it and so a heavier duty battery seems one possible solution.
Michael
Typically a cars immobiliser and alarm should take about 50ma so a 50AH battery should last 30 days and still have enough juice to start the car. Starting the car will typically take juts half an amp hour. So your battery at 50AH should be more than sufficient.
There could be one of three issues if you are getting problems. First is that car batteries arent designed for deep discharge and if you do that more than a few times you affect the capacity of the battery. That capacity declines with age anyway.
Second issue is that you may have a 60 am alternator but its unlikely ever to put more than maybe 45 amnps into the battery and then only when its deeply discharged. On my boat I have found that it takes almost 6 hours engine running to fully charge a 50% discharged battery with the charging rate dropping from 45 amps initially to less than 5 amps towards the end.. What I am getting at is that its very easy with a lightly used car to get into a vicious spiral of discharge and then not fully recharge .
Third issue is that you have something taking leccy that shouldnt be doing so whilst the car is standing.
None of these issues go away if you just buy a bigger battery.
uvk33n #470472 03/09/17 06:52 PM
Originally Posted By uvk33n
Originally Posted By madmax
How would this help? The OP's car has an isolator which he doesn't want to use as its use requires the windows to be reset. crazy3
Windows reset ????? Explain !! If I can undo a leather belt and open the bonnet and push a button then how difficult is it to 'reset' two windows !
Michael #470515 04/09/17 06:11 AM
Michael Offline OP
Reset is not difficult but with the right battery I won't need to do it, I just want to get in and drive my car and not have to open the bonnet every time I leave my car parked up and then again when I return to it and reset the windows
Michael
Aero 8 S4
Michael Offline OP
James
Thank you James for the link, those batteries look like what I am looking for, when the Aero is at home it is on the Ctek so I am only concerned about having a strong enough battery for trips away.
Michael
Aero 8 S4
Michael #470533 04/09/17 08:27 AM
James
- no problem Michael.
My suggestion is what I have done for my S1 ,Aero 8.I still get the dreaded 'click' from time to time but I have the reassurance of the jump starter pack should the battery drain in e.g. a hotel car park overnight, or whatever.
I tried a few booster packs but you need something fairly beefy for the V8 in the Aero;I went with this in the end and am very pleased with it -
https://www.amazon.co.uk/gp/product/B01CFJO88S/ref=oh_aui_search_detailpage?ie=UTF8&psc=1
James
Monkey Z125
Page 3 of 4 1 2 3 4
