1 members (New Zealand),
129
Old Book
Goodwood
Topics49,932
Posts838,511
Posts: 22,385 Likes: 358
Posts: 22,385 Likes: 358 |
I managed to get some time in the garage today. First I fitted the skids to the exhaust. No real reason for this except that it tidies things up and stops the crud accumulating on the mountings. Rear:  Front:  Next the windstop. I decided to upgrade the brackets on the Roadster with 2mm aluminium, and at the same time make some for Bumble. I used up some offcuts so the second pair are slightly smaller. It takes a while and a good deal of work to get to this stage:  Then cut the holes:   Old on the left, new on the right. I've modified the dimensions slightly.  Smaller pair for Bumble:  Adding U section neoprene edging:  Test fit: Thankfully these brackets work with the smaller head restraints!   Completed:
Posts: 5,661 Likes: 10
Posts: 5,661 Likes: 10 |
Good job Dave, very neat solution.
Martin (Deano)
Posts: 14,976 Likes: 2
Posts: 14,976 Likes: 2 |
Richard 1976 4/4 4 Seater
Posts: 3,482 Likes: 42
Posts: 3,482 Likes: 42 |
Dave, A) do the seat belts run ok with this in place? B) could you pm me the spec of the Perspex and the suppliers details please
Cheers!
Robbie Yes, belts work OK. Sourced from The Plastic Man (who else!)Same place as my spare wheel filler comes from. http://www.theplasticman.co.uk/index.php?area=calculatorFor the draft stop - Polycarbonate (unbreakable). You spec the whole thing, including radius of corners, I also have polished edges, and spec the holes, because they drill super clean holes. I need to dig out the measurements from the garage so I'll post them later......... You now have a PM packed with dimensions!
Post Photobucket Re-Boot from December 2013. I managed to get some time in the garage today. First I fitted the skids to the exhaust. No real reason for this except that it tidies things up and stops the crud accumulating on the mountings. Rear:  Front:  Next the windstop. I decided to upgrade the brackets on the Roadster with 2mm aluminium, and at the same time make some for Bumble. I used up some offcuts so the second pair are slightly smaller. It takes a while and a good deal of work to get to this stage:  Then cut the holes:   Old on the left, new on the right. I've modified the dimensions slightly.  Smaller pair for Bumble:  Adding U section neoprene edging:  Test fit: Thankfully these brackets work with the smaller head restraints!   Completed:
Posts: 2,274 Likes: 41
Posts: 2,274 Likes: 41 |
Craig Jezz
Posts: 15,794 Likes: 15
Posts: 15,794 Likes: 15 |
That is a great example of lateral thinking...well done!
Posts: 6,538 |
More great work from the Wellings Catalogue!
Well done Dave - you really could start a business!
Neil
