5 members (John V6, GrumpyPa, potty45, How, Graham, G4FUJ), 256 guests, and 43 robots.
+8Rich 96
John V6 51
Topics49,899
Posts838,024
Page 1 of 4 1 2 3 4
sarnia Offline OP
rain gets through bonnet louvres when car is parked stationary for a period of time , which has built up around the spark plugs causing the engine to miss ,
i have to remove the water by pushing kitchen towel around the plugs to soak up the water, its a 1994 4/4 zetec .I have made a pair of thin aly sections
which divert the water past the line of the plugs , the sections are fixed to the center bonnet hinge on both sides about 25mm loer than the bonnet and lift when opening .each aly section is hemmed to let the water divert forward and not to fall on the plugs, i have been using the car a lot in hot weather and it doesn,t seem to cause any overheating problems .the problem realy only happens when the car is stationary.
Where are you situated as you seem to have rain but a lot of hot weather. In UK we have not had much hot weather.
1992 plus4 connaught green
Sarnia, I see from your first post that you are living on the Channel Islands.
I fitted a second hand Ford engine cover to my car and do not have a problem.
I also covered the engine when washing it and when parked up in the rain overnight I put on the Phoenix car cover. Just some thoughts.
Ian
I can highly recommend "John Tailor's storm cover" for stationary in wet conditions.
Hannes
once: Green M3W; 2013
now: Red 4/4 Sport; 2011
I have exactly the same problem with my black top zebec.
I cover the engine when washing, but are planning to have a cover fabricated in the future.
4/4 2 seater 2001 model
I know I am a bit thick but how do you get that Sarnia is in the Channel Islands from the post?
It says Guernsey below his/her avatar?
Best Regards
Lang may yer lum reek
It's not that difficult to make a shield up out of sheet aluminium.
http://www.talkmorgan.com/ubbthreads.php/topics/167821/4
Hi John, I sometimes look at posters previous posts, gives me a 'flavour' of the person.
Eg lots of positive posts vs lots of negative posts.
In this case he mentioned his location.
Ian
Does the Plus4 engine that is used at the moment have the same/comparable vulnerability for water build-up that can cause trouble?
At first sight I do not see area's where I would expect water to collect.
I intend to cover the car when parked in the rain but should I also cover the engine when washing the car?
Regards,
Thomas
2017 Plus4
Page 1 of 4 1 2 3 4
