3 members (yobtaf, TBM, KennethM), 268 guests, and 88 robots.
+8Rich 78
Topics49,871
Posts837,679
Rudolf
#473859 23/09/17 08:34 PM
Does anyone know what gauge is the positive battery cable on a 12 volt 1965 plus4
Depends where the battery is located. If a four seater with the battery under the bonnet and only a relatively short cable run to the solenoid you could probably get away with 16mm2
If its a 2 str with a battery down the back and a long cable run, I'd go for 25 mm2 to minimise voltage drop.
Having said that, I've wired my Plus 4 4 str with 25mm2 but that's because I happened to have a length of cable spare.
I also used proper crimped on terminals and bought the special crimping tool to put them on, think it was less than 10 quid and produces a nice strong crimp. Use the proper insulating boots as well for a nice neat job.
Arwyn
The current is needed for the starter motor ensure you have a good earth. Modern starter motors have a gear reduction and because of this draw half the current but give twice the turning torque!
As Arwyn says its all about the current draw and volt drop
Triumph Herald 1969 13/60
Morris 1970
Thank You
